MHZ Mystic 1380mm build
  • drwayne
    • 2977
    #646
    Originally posted by Chrisg81983 View Post
    I see it you should be listening to him rite ?
    you're both comedians !
    • MrUnlimited
      • 94
      #647
      Certainly, I qualified my comment by "Rarely seen sq collets for FE motors at OSE".
      I used sq for 28+ yrs in nitro ( never ran gas )
      Are you serious ?
      I thought this was a serious thread .
      sorry.
      So tell me Wayne, why is a wellknown company like MHZ selling them for their own boats?
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        #648
        I like the idea of the normal type collets. Specially the MBP ones. They are so easy to get the shaft in and out. I use to hate taking out my shafts coz I never knew if it would get stuck or anything. With these its so easy!!!! And the have a fantastic grip. What flex size are you running? I'm only running 5mm, but I find it strong as!
        • drwayne
          • 2977
          #649
          MHZ cater a market higher than the rtr generics.
          Kent knows round is better because he was told so by it's GmbH promoter ... and in his experience it works well.
          Read the post again.. Ive not offered one as better the other, just a statement of fact.
          • drwayne
            • 2977
            #650
            DOC WHAT SO HARD TO TAKE SERIOUS ? How come you are always taking shots at kent ? from what I see he is very knowledgeable, and how I see it he has a faster or actually several faster boats. So how I see it you should be listening to him rite ? Please don't take this personal but I just been seeing you kinda be a **** to him in many posts so I was just wondering what the deal is. You are both smart men lets keep it at that. Thanks
            sent Pm.
            read and assimilate.
            • ManuelW
              • Oct 2010
              • 743
              #651
              To get some statements and facts in a weird conversation:
              -Kent is right, X457 is a good choice for a 54" cat with average weight and it makes sense to chose a setup suiting to run with this prop.
              -For the high-rpm fraction:
              HPR 135
              2x LMT 3040/9 with just 1167kv
              2x 8S 45C
              2x X457
              --> 98mph
              And thats not calculated or estimated, but I've built and driven it! Boat had around 9kg RTR and performance was pretty agressive.
              -square type couplers also can work for higher rpm's when the quality is good and the system installed well. JetCat delivers their turbines only with square type couplers and the Hydroplane version can spin up to 35.000rpm. Thrust me, there is still enough security.
              EDIT: I also got a set of square type couplers from MHZ for the MHZ Mystic 185 I'm building. Sent them straight back as well as the RC box they sold for an electric build
              regards,
              Manuel
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                #652
                "Kent knows round is better because he was told so by it's GmbH promoter ... and in his experience it works well"
                Kent also has square, but still likes round better, are you though?
                Why don't you build this boat, and share your experience with others. That's simply what I'm doing. Not because I was told.
                • Chrisg81983
                  • Jul 2011
                  • 1556
                  #653
                  I have ran square flexes many times at a pretty high rpm's in electric systems. I must say they worked fine, and I really never had a problem with them plus I achieved pretty decent speeds ( low to mid 80's ). Second I ran them in gas setups as well that had tons of torque/power & never once did I spin a square ended flex. I myself prefer round flexes but hey everyone has their own opinions.
                  • MrUnlimited
                    • 94
                    #654
                    Squares are less stressed under load since they move more freely and they don't break easily.
                    • Chrisg81983
                      • Jul 2011
                      • 1556
                      #655
                      Ok that's good to know thanks
                      • Alfa Spirit
                        • 2131
                        #656
                        What is exactly the setup for the Mystic?
                        - Motors and kV ?
                        - 10S batteries for each motor?
                        Thanks
                        • Xcesive8
                          • Jul 2009
                          • 395
                          #657
                          Originally posted by jkr View Post
                          My thought
                          Twin 12s 1527 90+
                          I thing it is possible also 1kg lighter.
                          Hi JKR, just to give you an idea.
                          I have a HPR135 it has twin 1527's 1.5y which is 825 or 850kv cant remember.
                          But i ran it on 12s a side once with some of my smaller props thinking id start slow amd work my way up.
                          It ran 86mph or 138 kph on 2 garmin forerunner gps.
                          Unfortunately it blew over and i cracked my hatch and it destroyed my schulze 40.160's cos i was in salt, along with batts etc.
                          Ive never got it up and going again since.
                          I had propshop 5517 or 5518 3 bladers to put on it as well as x457's but never got a chance.
                          So i think it would def get over 90mph with these motors.
                          Ryan
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #658
                            Ryan
                            That's exactly what I got with my 2250 Lehners 137km, but with 447props. I think both the 1527 and the 2250 are a bit on the small side for a hull this size, although mine were never intended for this hull. Definitely a huge improvement with the 2280's. I'm strongly considering running 12s in wye mode. Would be around 860kv. That would get me around 40k rpm and keep the current down. Should be real fast!
                            • MrUnlimited
                              • 94
                              #659
                              Guys,
                              I am moving this thread again upwards I like to know what servo do you guys recommend. How many kg's in torque? Will be 18kg be enough? 1/5 scale servo? I am updating tonight my blog.
                              • MrUnlimited
                                • 94
                                #660
                                Blog updated with 2 new pictures. www.v10power.ws
