Prather LapCat
  • FloatDaBoat
    Bare Bones Fabricator
    • Sep 2009
    • 368
    Prather LapCat
    Two months ago, our Rio Grande Racers (NAMBA) club president, Henry Keller, presented me with an old 31.75 inch X 13.5 inch Prather LapCat and stated, “Somehow, make it run”.
    This is the build after the fact:
    A portion of the cockpit bulkhead had been cut from the fiberglass prior to me receiving the hull, so I made a new bulkhead from 1/16 inch ply to make it water tight once again.
    I added 1 inch wide ply pads to the sponson bottoms to reduce the wetted area, & fabricated a motor setback mount of 1/8th ply, covered in epoxied fiberglass.
    I used 4-40 rod for the steering with 3 mm X 36 mm turnbuckles incorporated to allow for fine adjustment of the linkage lengths.
    Power is from a Leopard 4074 2200 Kv motor, Sea King 180 amp ESC (which I pulled from my yellow cat, as it needs a motor upgrade), & will get juiced by two Turnigy 2S 5.0 batts in series.
    I removed the cavitation plate from the OS leg & replaced it with a piece of 5/8 inch wide 1/16th aluminum to accommodate the dual water pick-up I fabricated, which will also allow access to the drive cable cover without having to first remove the original plate (due to it‘s length). I further modded the leg by cutting 7/16 inch off the bottom of the skeg, sharpening the leading edge, & adding a lubrication gizmo.
    I forgot to take a pic of the sub cowl hatch cover. It’s made from 1/16th ply with a water tight seal formed with silicone adhesive. I added enough foam floatation into the cowl itself to float it with the added weight of my Garmin Forerunner 201 GPS, which will be mounted under the cowl in a bracket constructed from fiberglass mat using polyester resin.
    Should get her wet this coming weekend. Finishing touches will come latter if the performance is adequate.
    Pics . . . . .
  • FloatDaBoat
    • Sep 2009
    • 368
    More Pics
    Four more photos . . . . .
      • 4297
      Looking very cool.
      Can not what to see it done and run,
      Video please I hope to come.
      • dana
        • Mar 2010
        • 3570
        Have you ever tried a water pickup like this?
        • dana
          • Mar 2010
          • 3570
          Looks good btw
          • FloatDaBoat
            • Sep 2009
            • 368
            Looking very cool.
            Thanks, lenny - - Will try & get someone to shoot a Vid.
            • FloatDaBoat
              • Sep 2009
              • 368
              Prop-Wash H2O Pick-Up
              I haven’t used a dual prop-wash water pick-up before, but can’t see any reasons for it not working well.
              The primary tube used in it’s construction is 5/16th inch O.D. brass, while the secondary tubes are 5/32nd inch O.D. brass. I sweated extra lead free (95% tin, 5% antimony) solder into the primary tube from the secondary tubes side, then removed the excess by drilling it out with a hand held chuck. The result was a cone shaped transition from the primary tube into the secondary tubes. Should flow H2O like Gangbusters!!!
              See even more pics . . . . .
              • Stinger9D9
                • Jun 2007
                • 355
                I remember seeing Prather Lap Cat's in RC Modeller Magazine back in the early 1980's so it brings back good memories. I've always wanted one, but I'm not a real fan of nitro (always liked FE).
                With the power available to us FE guys nowadays, I knew it must be possible, but those hulls are getting harder and harder to find anymore.
                This build of yours really is top notch. From the bulkhead repair to the steering linkage to the motor mount, everything looks great. It will be interesting to see how it runs. Those ride pads look sweet. I really hope this thing rips.
                Can't wait to see it run.
                • Stinger9D9
                  • Jun 2007
                  • 355
                  Any updates on this one? I'd love to see how she runs/ran.
                  • FloatDaBoat
                    • Sep 2009
                    • 368
                    Not yet, as it's been too windy. Hopefully, I'll get to do the maiden run this coming weekend W/Video.
                    • Stinger9D9
                      • Jun 2007
                      • 355
                      Any updates?
                      • FloatDaBoat
                        • Sep 2009
                        • 368
                        Only Bad News
                        The LapCat has yet to complete a full lap:
                        On my initial attempt, the steering servo was defective (had a bent idler shaft), which overloaded & caused the RCVR to self destruct also.
                        After repairs, the second attempt resulted in the hull blowing over at 48.3 MPH, according to the GPS reading.
                        I had the lower unit set at zero degrees with respect to the sponson bottoms.
                        My next attempt will entail dialing-in some negative prop shaft angle, along with adding ~ 3 ounces of lead weight in each of the sponson tips.
                        This boat is light & has a tunnel width of 7 inches (which was one of my initial concerns), causing it to pack gobs of air.
                        This project may be a lost cause, but I’ll give it one more try before abandoning it - - Lots O Luck !!!
                        • FloatDaBoat
                          • Sep 2009
                          • 368
                          Short LapCat Vid
                          I added ~ 3 Oz. of lead to both sponson tips, adjusted the lower unit for some negative thrust angle, & managed to get a short run accomplished; the results were degraded due to a hooking tendency in the turns & the malfunction of the LVC in a brand new Sea King 180A ESC. That is the 3rd Sea King 180A ESC I’ve owned that has suffered this failure - - guess I’ll install Lipo Shields on all future ESC’s from the get-go.
                          My buddy took the attached vid, & he has had no prior experience taking videos, so please excuse the lack of expertise.
                          Top speed achieved (GPS) was 47.0 MPH, and the hull was running very wet, with no hint of a blow-over as on the first run. Next attempt (after installation of a Lipo Shield) will be to remove the negative thrust angle. I might yet get this LapCat to run decently: Lots O Luck !!!
                          YouTube Link
