I got this in a trade from a member here and decieded to build if i got a little of the way installing mat with fg resin that i mixed weak to not warp the abs hull but ill try to have regular post from now on i also fabbed a mount and installed some rails at 4"
BBY ovalmaster 26
flex
http://www.hobbyking.com/hobbyking/s...ible_axle.html
shaft
http://www.hobbyking.com/hobbyking/s...th_thread.html
drive dog
http://www.hobbyking.com/hobbyking/s...dproduct=12713
stinger
http://www.hobbyking.com/hobbyking/s...e_Silver_.html
trim tabs
http://www.hobbyking.com/hobbyking/s...Trim_tabs.html
havent chosen a rudder or turnfins yet but this is what i was thinkingAttached Files
Installed trim tabs stuffing tube and support for stuffing tube
looking good i hope your glass will hold better than mine did it did not stick to the abs very well, probably my fault though, i used ca and 2 layers of glass on my OM29 also stringers thing was hard as a rock. i am interested to see it with the ul-1 power i think it would be a force in a P-limited mono class
got it painted will join tomm and double clear coat
Paint looks good dude! you are almost there. we are starting to develop P LSO class here, so when you make it down, you will have some competition.
nice job!"Look good doin' it"
See the fleet
i tried this out because it said it bond to plastic, but i will also clearcoat it with a clear laquer
