32" Mono Build
  • Remmie81
    • Apr 2012
    • 134
    32" Mono Build
    I was looking for a electric playboat next to my gasboats and found this 32" Mono that is solled all over the world under a different name
    Here is the setup im going for:
    Leopard 4074 -2150Kv
    Turnigy 180Amp Esc
    Turnigy 5S 5000Mah 30-40C Lipo
    Prop: any recommendations welcome
    First started out with making the Lipo tray:
    DONE!
  • Remmie81
    • Apr 2012
    • 134
    Then its time for making the motor mount (this is not the finished motor mount yet):
    • Remmie81
      • Apr 2012
      • 134
      Then the boat itself finally arrived
      • Remmie81
        • Apr 2012
        • 134
        There was a little bit to much flex in the bottom, so took care of that with a layer of Carbon/Kevlar
        • Remmie81
          • Apr 2012
          • 134
          Goodies!!
          Rudderblade a little bit to long, so this will be shortened
          • Remmie81
            • Apr 2012
            • 134
            Now I have to go back into my hobby room to continue building and making pictures
            • ozzie-crawl
              • Sep 2008
              • 2865
              The carbon kevlar looks sweet. They run well those monos.
              Before anyone else asks. Were did you get that stinger,looks different.
              • Remmie81
                • Apr 2012
                • 134
                Thanks!
                I got it from here: http://www.horracing.com/product_inf...64e34jkjobqnf4
                Its a nice thing as you can adjust the length of the drive by just screw it in or out.
                • Remmie81
                  • Apr 2012
                  • 134
                  Ok, ive done a little bit more:
                  Lined up engine and brass tube
                  Get everything in place at desired CG and mark it with some painters tape
                  Equipment out of the boat and sand the places were the glue needs to come
                  Done!
                  Use a Lipo and old big Brushed engine as weight for lipo tray
                  Now have to wait untill the Polypox700 (2comp glue) has done his work (Should take approx 24 hours) before I can continue
                  • mtbenjamin77
                    • 761
                    Very nice build my friend. I'm looking to build almost the exact setup. Same stinger, but different longer trim tabs, but I'm not sure I can get them to fit right. I was thinking maybe using mounting the rudder on the left side so I can turn the bracket to the outside of the boat so I have room for the taller trim tabs. Also, I was planning on using the leo 4082 1800 on 5S I wasn't sure if the 2000 would handle 5S, any thoughts?
                    • Remmie81
                      • Apr 2012
                      • 134
                      mtbenjamin,
                      I dont think it need bigger taps. do you have them already, otherwise you can maybe swap them for smaller ones?
                      I would not put the rudder on the left myself.
                      Your motor and lipo setup should be good!
                      • mtbenjamin77
                        • 761
                        I guess I wouldn't have to mount it on the left side I would just have to turn the bracket around so that the screws are closer to the side. Thanks for the helps remmie. I'll post some pics once I make some progress. I'm still waiting for parts. Thanks again my friend.
                        Travis
                        • steveo
                          • 1454
                          man that is not alot of glue around that motor mount, i did something similar to that and motor came unglued might want to considered a little more reinforcement especially during a high speed crash
                          • mtbenjamin77
                            • 761
                            Yeah I usually add a small piece of cloth on both sides of each support. I learned that the hardway.
                            • Remmie81
                              • Apr 2012
                              • 134
                              @Travis,
                              Your welcome
                              @Steve
                              Thanks for your feedback.
                              Normally I first "tack-down" the motormounts with 5min epoxy and then fix them with 24 hours epoxy.
                              This time I wanted to go stronger because of the reason you just gave (high speed crash) so directly started with the 2comp glue as far as I could reach.
                              Tomorrow when the glue is hard, i can take out the motor and reinforce the innersides.
                              EDIT: normally I do use cloth for reinforcement but this Polypox glue is extreme strong stuff. In my gas-engines boats the engine rails dont come loose with only use of this glue.
