First build... Cheap boat, lots of power
    • 6057
    #256
    My bad...................his photo of it on the first page shows it the watercooled model!!
    • masonis1
      If you cant control it 👍👍
      • 1177
      #257
      There is a water cooling jacket on the motor and esc. I have inlets and outlets from ose but they dont seem to let much water through...
      When speed isnt the option, change your ways
      • masonis1
        • 1177
        #258
        I was planning on taking water in from rudder, Y it off to esc and motor then the exits Y into one and out. How does that sound?
        • izcain
          • Mar 2012
          • 274
          #259
          ok so you already have a water cooling jacket for the motor then?
          CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
          • masonis1
            • 1177
            #260
            Yes. The water jacket is built into the motor. Its a 3650 motor with a jacket making it 3656 i THINK.. hah
              • 6057
              #261
              The motor has got me confused, i know the Turnigy motors very well, but this one looks like it has a built in jacket........is that right?
              • masonis1
                • 1177
                #262
                That is a built in jacket correct.
                • masonis1
                  • 1177
                  #263
                  I have another extra motor outside the boat if you would like pictures to see.
                    • 6057
                    #264
                    Do this...................measure the can from the front to the rear not inlcuding the shaft or water connectors sticking out the rear...............how many mm is it............56......60...........???
                    • masonis1
                      • 1177
                      #265
                      Let me check real quick. Ill be back soon.
                      • masonis1
                        • 1177
                        #266
                        It says 66 mm on my ruler but that seems wrong.
                        • masonis1
                          • 1177
                          #267
                          So maybe 10mm of jacket? I have no idea. Also how do they get 36?
                            • 6057
                            #268
                            Yep............the extra 10mm is the area in the back where the water flows in............its a 'true' 3656 motor then and will give you power like your not expecting with that hull
                            36mm is the diameter up front
                            • masonis1
                              • 1177
                              #269
                              Hah is that a good thing? I will be getting a 5s for my 1/8 truggy, i might wanna try it in this thing.. hahahah
                              • izcain
                                • Mar 2012
                                • 274
                                #270
                                lol this sounds like it's going to be like my old hitec sea nymph with the velineon swap on 3S. You can't go much past 1/2 throttle
