First build... Cheap boat, lots of power
    Measure them Mason 3660 is 36 mm in Diameter and 60 mm long. It is an inrunner right?
    • masonis1
      If you cant control it 👍👍
      • 1177
      #992
      The motor thats in my first project is the same as the motor im talking about now.
      When speed isnt the option, change your ways
      • izcain
        • Mar 2012
        • 274
        #993
        Mason by the look of that prop you could detounge it a little to give you some additional top end performance.
        CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
        • izcain
          • Mar 2012
          • 274
          #994
          Also I totally agree with turning you servo down to not have as much throw I have mine turned down some as well on the fightercat boat since it will flip right over at speeds with sharp turning.
          • masonis1
            • 1177
            #995
            Ok and whats detourenge or whatever? I will try turning the servo down. I might have to put the traxxas 2.4 in so i can adjust epa.
            • TheShaughnessy
              • 1461
              #996
              to the motor? It prevents the wires from melting the stock shrink wrap and shorting out, which is a common issue with these motors when you run them for a long time with the larger props. and a long time in rc boating isn't very long sometimes 30 seconds is all it takes to blow a motor.
              the ul1 is a 3656 so the dimensions are slightly smaller but it is also six pole and a more appropriate kv. the 3660 you speak of, is the one in your project boat? I would leave the motors where they are.
              • TheShaughnessy
                • 1461
                #997
                detounging is when you remove some material from the leading edge of a prop to get rid of the low pitch area. It is done to gain more high end, the extra bite you loose for. I wouldn't suggest trying that just yet. You would need a balancer at the least. Take a look at an octura x series vs the m series. The m series is a detounged x series and you can see the missing tounge area in picks
                dang i cant keep up, people posting as im typing.
                I have no idea how this thread got to be 1000 post long
                • izcain
                  • Mar 2012
                  • 274
                  #998
                  Detounging also tends to lower the amp draw and be easier on the motor on takeoff from what I have seen.
                  • izcain
                    • Mar 2012
                    • 274
                    #999
                    Never thought I would see
                    • izcain
                      • Mar 2012
                      • 274
                      #1000
                      1000 posts!!!
                      • masonis1
                        • 1177
                        #1001
                        Sure thing. Hah in about a month or so? Hah id say thats good. And im already on boat number 2.
                        • masonis1
                          • 1177
                          #1002
                          Will this prop be fine for what im doing with it? Just a go fast boat, take it to the lake and race the big boats. Hah
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            #1003
                            Gotta be a record...................thats about 40 posts per day.
                              That's keeping up with our MG thread but it's been months in the making.
                              • masonis1
                                • 1177
                                #1005
                                Hahah wo
