First build... Cheap boat, lots of power
  • izcain
    • Mar 2012
    • 274
    #526
    you may need a way to cut that stand down some as well, depends on what Mark is sending
    CF Fightercat Daytona, 21 year old Hitec Sea Nymph, Genesis and many more to come im sure.
    • izcain
      • Mar 2012
      • 274
      #527
      http://www.offshoreelectrics.com/inf...ass-tubing.php
      read thru this it will explain everything
      • masonis1
        If you cant control it 👍👍
        • 1177
        #528
        Thanks and i have a dremel to cut it down.
        When speed isnt the option, change your ways
        • masonis1
          • 1177
          #529
          Is the stuffing tube bent?
          • izcain
            • Mar 2012
            • 274
            #530
            The one I sent you is a brand new one with a little extra length to it. You will have to bend it fit it and cut it
            • masonis1
              • 1177
              #531
              It needs a bend in the boat? Im confused. New to all this... Anyone have pictures of what it looks like in the hull?
              • izcain
                • Mar 2012
                • 274
                #532
                Yours may be justa strait shot but every boat is different.
                • masonis1
                  • 1177
                  #533
                  Ill have to findout when i get it.. hopefully its just like that.. so tomorrow...
                  EVERYONE needs to beable to help. Hahah jk. I know where to put the tube going through the transom, do i mount everything else from where it sits from the tube or so i measure it some other way
                  • izcain
                    • Mar 2012
                    • 274
                    #534
                    You may have to put a small bend in the tube after it goes thru the transom so that it lines up with the strut correctly. Just be sure to take your time with the tube since they like to bend super easy if you dont get them heated right or try to bend them without a flex shaft in them
                    • masonis1
                      • 1177
                      #535
                      Ok.. hah im getting nervous... But i guess yall will be here to help when they get here... Im going to bed. Any input, info, tips can be added. Everything is helpful
                      • masonis1
                        • 1177
                        #536
                        Hey zac im on my phone at school working out. Does the tracking say if it was delivered
                        • masonis1
                          • 1177
                          #537
                          Ok ok ... Got 2 packages on my back porch. Time to get busy
                          • masonis1
                            • 1177
                            #538
                            . It's here its here. Let's start the build...
                            • masonis1
                              • 1177
                              #539
                              Thanks again mark and sac for everything
                              • izcain
                                • Mar 2012
                                • 274
                                #540
                                No problem man! Glad to see everything survived the trip well! Just take your time and measure everything out! It will go smoothly!
