First build... Cheap boat, lots of power
  • masonis1
    If you cant control it 👍👍
    • 1177
    #181
    I will keep searching. Got paint, sandpaper, primer, etc. Ready to paint. Going home, cleaning boat, whiping it down with alchol and gunna start painting..
    When speed isnt the option, change your ways
    • masonis1
      • 1177
      #182
      I can get a rudder for 7 bucks and then i would need to find a strut..
      • h2o 1
        • Sep 2011
        • 854
        #183
        Cool, start the painting and hold off on the hardware a bit. Make a wake and slash will be checking in and maybe they know of better or more affordable options for you on the hardware.
        • masonis1
          • 1177
          #184
          Ok cool. Have the paint can sitting in warm water and the hull is ready to be primed
          • h2o 1
            • Sep 2011
            • 854
            #185
            Take ur time bro! several thin coats is always better than one thick one.
            • masonis1
              • 1177
              #186
              Gotcha. Directions say wait 30 minutes before sanding. Waiting for the hatch to dry a little more and ill start sanding
              • h2o 1
                • Sep 2011
                • 854
                #187
                I would wait a little longer before sanding Mason,tho the primer may seem dry to the touch,underneath its still not fully cured
                • masonis1
                  • 1177
                  #188
                  Ok sounds good. Im gunna wait until 1 to sand the hull. The hatch was pretty bad, got it all smooth and resprayed it. Got the bottom of the hull sprayed. Seems smooth but there are some spots where its not.
                  • masonis1
                    • 1177
                    #189
                    I'm gunna post some pictures. One is the prepped hull. The others arevthat rudder and strut set.
                    • masonis1
                      • 1177
                      #190
                      • h2o 1
                        • Sep 2011
                        • 854
                        #191
                        Yeah, the primer will let you see it all! lol, but its ok cause its only primer and you can sand them out and touch up the bad areas once sanded
                        • masonis1
                          • 1177
                          #192
                          Im glad i saw that. Should 2 coats of primer good enough?
                          • h2o 1
                            • Sep 2011
                            • 854
                            #193
                            As long as evenly coated and you cant see thru the primer you should be good.Again, if u use that srut and rudder,you will have to make a stand off,even more of a stand off with this one!
                            • masonis1
                              • 1177
                              #194
                              So am i suppose to get which one? Im still confused on which one i need and im fine with making stuff.
                              • h2o 1
                                • Sep 2011
                                • 854
                                #195
                                That one will work Mason,you will just have to make a stand off out of a small block of wood to keep the front of the strut out of the hull of the boat
