55" Segad Gas to FE build...
  • keithbradley
    • 3671
    #106
    Originally posted by Rob DeAngelis View Post
    I do... thanks again man
    Try a smaller prop (especially if you're going to go up in voltage). I bet if you go down a couple sizes in props the oscilation will be gone (the bouncing of the front of the boat and the boat coming out of the water). It looks like that prop is lifting the hull out of the water no problem, but you would be surprised how much better it will handle with a bit smaller dia prop...
    www.keithbradleyboats.com
    • Rob DeAngelis
      • 296
      #107
      thanks bro... im on it... what do you think of going with a smaller dia but 3 blade?
      Lakeside entertainer
      • keithbradley
        • 3671
        #108
        You could...I personally like two blade props better in most applications. Usually in terms of mph/amp, two blades usually win out for me.
        • Old Sloppy
          Harry from Atlanta
          • Jul 2007
          • 201
          #109
          Rob,
          I enjoyed the video.
          try 9s lipo with a Y557/2 prop, propshaft may get raised up a little.
          Harry
          From Atlanta
          60" Expresscraft SuperCat
          (2) 2028 Castle motors 64.7 mph
          10s3p with x450/3 props
          15,000 mah 40c cells,
            • 9481
            #110
            what the kv on this setup?
            thanks
            • wes777
              • May 2012
              • 7
              #111
              Rob looks great. I've been waiting to see her run. I have a 58" i'm just trying to figure out what i'm going to put in. please keep posting.
              • Rob DeAngelis
                • 296
                #112
                910 kv
                thanks
                • Rob DeAngelis
                  • 296
                  #113
                  im looking for a castle hi 240hv next... still working on my refund from sf... if they send me a new one instead of a refund, it will be up for sale asap... 200 takes it
                    • 9481
                    #114
                    910 kv
                    Thanks!
                    any more runs on this cat?
                    • Punisher 67
                      Ignore list member #67
                      • 1616
                      #115
                      Really nice run Rob - nice to see your boat finally in the water .
                      • Old Sloppy
                        Harry from Atlanta
                        • Jul 2007
                        • 201
                        #116
                        have you tried any new props or cell counts ?
                        Harry
                        • avinash inalsingh
                          • Nov 2012
                          • 29
                          #117
                          hi...i have the 55 king of shaves and the segad 55...my setup is scoriion 4035-800kv 12s and i just ordered the 300 swordfish esc....i am yet te see what iy can do...i am presently running a pro mod cc racing engine in the king of shades...i will like to know more about you findings..thanks..
                          • avinash inalsingh
                            • Nov 2012
                            • 29
                            #118
                            now saw the video!! kicks ass...my experience with large cats, a 3 blade prop is better..but i guess everything is trial and error..i changed the height of the prop setup to a shorter one...centre of the shaft is exact height to the bottom of the sponson.(pontoon) well done i am waiting to see what i will do >>
                            • dana
                              • Mar 2010
                              • 3660
                              #119
                              What was the strut height before? I would raise that sucker up above the sponsons
                              • Old Sloppy
                                Harry from Atlanta
                                • Jul 2007
                                • 201
                                #120
                                centerline of propshaft 3/8" up from bottom of sponson. (may run even higher as needed.)
                                Harry
