ML Boatworks New Sport 20L (Long version, 33.5") Hydroplane for FE or nitro
  • cybercrxt
    • 2926
    GP335- 33.5" sport 20L
    GP400- 39" sport 40
    Well, the first kits arrived today for the ML Boatworks Sport 20L 33.5" full P sport hydroplane. I quickly framed one up as I just had to see how it looked compared to the Sport 20 31" version for P-limited applications. This thing is going to be awesome! As you can see, it has a wider stance, its longer, and it engulfs the Neu 1512 motor I layed in it. As you can see, (2) Hyperion, 4s, 35c, 5000mah packs sit easily inside. It has a 5" engine well, with plenty of space under each side deck. Uses the same cowling as the sport 20. It also has the built in Steering Servo Frame so no extra servo bracket is needed. Should be awesome out on the water! I will be quickly getting this one ready for its first run! Enjoy the pics. I did side by side comparisons, 20L vs. 20 in the pics. Enjoy, Mike www.ml-boatworks.com
  • cybercrxt
    • 2926
    Hull length and engine well width comparision pics:
    Sport 20L:
    Sport 20 P-limited hull:
    • cybercrxt
      • 2926
      Battery Motor comparisions, 20L vs. 20:
      Sport 20L, 4s2p w/ Neu 1512:
      Sport 20 P-Limited, 4s1p or 2s2p w/ UL-1 Motor:
      • cybercrxt
        • 2926
        And as you can see, both hulls use the same cowling. The soon to be ready Sport 40 also uses the same cowling!
        • Serpents811
          • Oct 2011
          • 381
          moving up on the world ,,,, i like that mike
          • cybercrxt
            • 2926
            Thanks Tommy, Wait till the sport 40 is done. Its a 39" version. Talk soon, Mike
            • Serpents811
              • Oct 2011
              • 381
              • Grazacind
                • Jan 2011
                • 351
                Looks great Mike cant wait for the naughty sister to my QS370 to happen.
                Cheers
                Andrew
                Andrew
                Find it + Buy it + Twin it + Run it = WOOHOO
                • cybercrxt
                  • 2926
                  Haha, yep, yours is one of the 3 I am working on. I will keep you posted. Mike
                  • Grazacind
                    • Jan 2011
                    • 351
                    Mike let me know when you you would like payment mate. I am ready to go when you are.
                    Andrew
                    • cybercrxt
                      • 2926
                      I will discuss that with you soon Andrew. The sport 40 frame kit arrived today. I immediately got to work! Its big! Enjoy, Mike
                      • Darin Jordan
                        • 9446
                        Mike, what are you using to glue these together at the frame joints?? Is it CA??
                        Just wondering how you are able to get them together so quickly and so nicely, because, well... I want to be able to do that too!
                        Look GREAT!
                        Darin E. Jordan - Renton, WA
                        • cybercrxt
                          • 2926
                          Hey Darin, its CA. I put just enough to hold the framework, then I thin out west systems epoxy enough that it will flow up underneath the joining frames. That is what creates the permanent bond. Im not sure what else could be used to hold things fast do you? Mike
                          • cybercrxt
                            • 2926
                            More progress today on all the hulls, and did some initial fitting on my Sport 40, 6s1p either 45c 5000mah or 35c 6500mah setup, Neu 1521...Gonna be TONS of room in this thing! Mike
                            • cybercrxt
                              • 2926
                              More done, and as you can see the first 20L and 40 hulls are rolling off the assembly line. I hope to have them both in the water in the next couple weeks! Enjoy, Mike
