Originally posted by monojeff
View Post
I might be a bit confused-- on the silicon-- are you talking about using silicon sealant, or using silicon as a lubricant for the shaft?
The driveline has bushings only, including the strut, so I was only using a drop of oil on each bushing to lube it. Not sure how greasing the shaft would help anything if the friction points are only on the bushings (not like a flex shaft).
I'm using this rudder:
http://www.offshoreelectrics.com/pro...d=ros-mini-rud
Seems kinda small but it is what the builder recommended. Let me know if there is a better option
I'll mess around with the lipo positions. My boat is set up for RHT (rudder is on the left hand side of the transom, and turn fin is on the right side). Do I want the weight biased to the inside sponson (in my case, the right side) or the outside sponson?
I was considering adding an air-dam as well. If you have any pics on how you installed yours that would be great.
Cheers,
Chief
