HK f1 Tunnel
  • ice_spy
    • 136
    HK f1 Tunnel
    Im a sucker for the F1's, so ive decided to see what limits i can push a cheap HK Hornet F1 Tunnel hull too.
    I will use the supplied cheap outboard unit something breaks, and then upgrade from there, to alloy or FRP leg.
    Initial test runs cooked the cheap motor (should have cooled the motor before esc) but the esc has held up, possibly because i added an extra cap to it. With a prop change at approx 60klm on 3S she made a spectacular blow over and amazing, completed a full 360 loop, and was able to drive it back to shore. With a rear heavy CG and at zero trim, I admit full throttle into a slight wind was its downfall.
    Motor will be replaced with a leopard 2900kv, battery will remain at 3S, ESC will be upgraded to a T180 or T120.
    Next stage the motor will be upgraded with the leg to a leopard 540 on 6S.
    I removed the hornet and sponson stickers, replacing with some small sponsers and 'Mercury Racing' team stickers as the main cowl sponser. I will remove the blue & silver hull stickers (yellow is painted) & recolour in red with black to match mercury's colours, cut out the window and add a sheet of clear lexen, possibly a driver head. ( I like my scale realism)
    Next i applied decals to the outboard,2.5 EFI mercury. And replaced the mounting bracket with a K&B 7.5 adjustable mount. The mount will then be bolted to some alloy U channels to enable up and down trim without breaking the transom bolt seals, and also act as a stand of bracket for better performance.
    As these hulls are very light, i cut out the front section to gain access for glass work, and later to be able to get my hands inside the front cockpit to place the lipo for more forward CG. I layed up an overkill bias ply glass sheet, covering the sponsons to seal the center section, giving air tight flotation, however will add noodles in the center incase of split decks.
    Although adding a fair bit of extra weight, the heavy glass will hold firm electrics, hull and transome when she deciedes to take another higher speed flip.
    With the supplied radio box and batt tray removed, the steer servo will be hull mounted along with the esc and RX, then a bulk head will seal this rear compartment area from the forward lipo tray. The fuselage will then be sealed with a piece of bent perspex for the front half, and seperate sheet for the rear compartment.
    I hope weight is not going to kill the project. I need some digi scales
  • ice_spy
    • 136
    Bolted on the adjustable mount, now when i want to adjust height, i can simply loosen the 4 outer bolts and slide the motor mount up or down, without having to reseal the transom bolts and access them from the inside. The U channels also give the motor a 10mm stand off, allowing the prop to run in cleaner water, less porposing and quicker planning. A longer boat at high speed also helps seeking (wanting to swap ends).
    • galant2door
      • 98
      Those outboards look alot like the dolphin outboard on my old kyosho tunnel. Will be watching as I to like the tunnels
      • ice_spy
        • 136
        Cut out some perspex and heated the front piece on the stove at low heat. I then placed the warm saggy perspex onto the boat and pushed it into shape.
        At first i ran a bead of silcon on the boat around the sealing areas to make a water tight seal. However without a perfect bead, it left too many high and low spots to fully seal. I removed the old silcon and started again. This time i put some vaseline onto the bottom of the perspex and ran another bead of silcon on the boat. Before touch dry, i placed the perspex onto the boat to make a perfect seal. I will have to wait for 72hrs now before i attempt to remove the perspex lids.
        I may have pulled the perspex down too tight with the screws, so maybe i will have to try again leaving a thicker seal of silcon.
        They will be held on with some thumb screws for quick release, at least on the front section for quicker battery removal without a screwdriver.
        As i will be solid mounting the steer servo to the hull, i was thinking of a production vertical servo mount, quick easy to glass in. Or i have some T channel alloy i was thinking to bolt onto the transome though the motor bolts and glass in the front piece from the sides of the fuelage, cutting the ends of the servo into the T alloy as well as bolting. Then some holes to lighten it up some more. I can see a CNC on the way...
        • ice_spy
          • 136
          bolted the servo into the hull, the rear piece is held in place by the transom bolts, the T alloy section also acts as a transom brace against the motor pulling out. The front will be resined into the sides of the fuselage. Once resined in, i will drill a couple of lightening holes.
          Now i just need to resin in the wooden battery tray that was supplied with the boat, closer to the bow for better CG.
          Next I will be mounting the esc and the RX.
          Im still not 100% happy with the silicon seal, it does need to be thicker. I just wanted a water tight seal that i dont have to use hockey tape everytime to seal.
          Does anybody have any suggestions?
          • ice_spy
            • 136
            Mounted the outboard back up fitted with a test motor trinity 13.5t 540 size BL from an old touring car i had laying around. Took the boat for a test run but it was a bit windy. The extra weight held it on the water a lot better. thinking of a leopard to get it moving along now.
