building of a Mystic 1140mm in Belguim
  • silver
    • 77
    Hi,
    After Months of waiting, looking for info and spare parts.
    Better start to build now as summer is almost here.
    I'm Building a MHZ mystic 1140mm
    on board two leoparts 4082 2200kv
    still on the shopping list:
    - Props
    - Esc
    - batterys
    - loader
    Hope to post something soon how the building process goes.
    regards Silver
  • cyprus31
    • Jun 2011
    • 140
    Good luck of your building proccess Silver. Many things to be done but take it slowly-slowly
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      Hi silver, to answer your question about motor placement, sure can do. But wait till you have the struts mounted. It's not suppose to be random, but rather depends on all your other parts to hit a COG of around 35% so a good idea would be to have all parts and place in the hull ( I mean everything including batteries hoses wires ) and measure. It gets tricky if you end up at 40% and have to add weights in the rear. All the best with the build. Just ask if you need help.
      • cyprus31
        • Jun 2011
        • 140
        Just another question which just came up Kent.
        Do you know exactly the COG of the Mystic 114?
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1837
          Mmm, I don't think it can be 100% the same on all, I think the slightest angle difference or props or whatever could change it. Mine is around 38% at the moment and I sometime fear it will blow over. But if you have the stingers/drives at 0 to -1 degree it will make things easier. Again if I could get mine up to speed would also help to see if it need a change. I think your speed sounds ok you are using 45 props yes? Maybe 47's will get you 120? How fast you want to go anyway? Are your stingers 100% aligned in all directions? Have you measured?
          • cyprus31
            • Jun 2011
            • 140
            On my first run I had the stringers at 0 degree (full up) and with the 45 props I needed to add extra weight in front. Besides the 2x6s I had to load the boat with another 2x4s cells just to keep the nose down and to avoid going inverted in water.
            Yesterday I lowered the struts down to -1 degrees and removed the extra cells for wheight. I must say it was more stable but the whether didnt hepled at all. On my first hight speed run the nose lifted up and landed inverted in water. All my carbon mounts of esc and servo came off place and now I must start the building - glueing from the beginning.
            Kent I have tried normal epoxy to glue the carbon legs but no success. They came off after the first run without flipping. Just from water bumping. Then i sanded the base again and used steel epoxy but again the came off.
            Today I got fiberglass mixture to try. Lets hope it will hold. Otherwise I will remove everything and place them into position with velcro.
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              Nick!! That sounds really wired? How can the mounts come off? And where did the glue let go? Did you sand/scuff then used acetone to wipe both hull and carbon mounts? The glue should cover the little mount all the way around including over the mount. I think I would brake the hull if I tried to remove them. Please take a photo and send to me
              • silver
                • 77
                Ho that’s sound serious, I’m going to use yachtcare Super Epoxy from the trademark Vosschemie.
                This transparent stuff will be holding everything in place.
                Good luck with rebuilding the parts
                • silver
                  • 77
                  hi,
                  i'm thinking about ordering a pair of GP/4714/2/LH/BR and GP/4714/2/RH/BR for the mystic 1140
                  hope that this is a good starting prop to try out.
                  any comments are welcome.
                  Silver
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    Should be a good start are your motors 1600kv or 2200?
                    • silver
                      • 77
                      I'm running the 2200 Leo's :-)
                      • cyprus31
                        • Jun 2011
                        • 140
                        A good start of props if you are running Leopard with 2200kv will be the 445/2 L/R and then go to higher diameter
                        • silver
                          • 77
                          ha thanks, i will order them in Germany becausethe props. the propshop in uk doesnt have the R ones only the size bigger.
                          so i will order also the flexshaft safety and the flex shaft with square end to make sure i will not lose a shaft.
                          the rest of the building goes ok
                          pictures will follow
                          • cyprus31
                            • Jun 2011
                            • 140
                            Lets see some photos Silver
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              Silver, you dont need square ends on the cable. Remember you do need a left and right cable
