DF22 Finished!
  • OJ racer
    • Dec 2007
    • 179
    DF22 Finished!
    I finally finished and successfully tested my DF22. I'm currently running an x432 prop, dual 8.4 volt nimh batteries in series, a Feigao 540L 10 turn, and an X-Power 100a ESC. To prove it, here's a video on youtube of it:
    The guy speaking with an English accent is my friend who's filming it.
  • calcagno45
    • Mar 2008
    • 1050
    Nice job. Get some pics of her to put up here.
    • OJ racer
      • Dec 2007
      • 179
      Did you see the vid?
      • OJ racer
        • Dec 2007
        • 179
        Here's some pics. A few things: I replaced the blueish tubing with the orange, the blue was too big. The output has ductape around it because I got the output for the large tubing, which I didn't use. For the sake of statistics, that boat is also a bit of a heavyweight for 22 inches: it weighs in at 4 pounds 14.6 ounces. However, with that motor and ESC, it accelerates like a Ferrari.
        • OJ racer
          • Dec 2007
          • 179
          Here's a few more pics. Those batteries are held down with industrial strength velcro. My mom used it on our dog's jacket. I figured if it can stand up to a full grown GErman Shepherd it can stand up to batteries going 0-30 in a second. I was right.
          • OJ racer
            • Dec 2007
            • 179
            Keep in mind, this is my first FE build. The fastest boat I had before this was a Traxxas Blast. I'm very happy with this build.
            • Steven Vaccaro
              Administrator
              • 8934
              Looking good. Good job with the first build. Try running the boat in a clockwise circle, it will skip less. Also can you take a picture of the turn fin from directly behind it and post it?
              Steven Vaccaro
              • OJ racer
                • Dec 2007
                • 179
                I can do that.
                • Heath M
                  • Mar 2008
                  • 865
                  Gr8 job,
                  Nice looking lake too, looks quite cold there
                  i'm glad i live in the tropics
                  Heath
                  Brisbane,QLD, Aussie
                  • OJ racer
                    • Dec 2007
                    • 179
                    Here it is:
                    • OJ racer
                      • Dec 2007
                      • 179
                      It is cold. In the vid if you look far out you can still see a good few thousand square feet of ice floating around. That's what I call a glass of ice water! Although, it makes the water cooling work great. I can run 16.8 volts through the motor, and when the bats are dead the motor is in 2 digit temps.
                      • OJ racer
                        • Dec 2007
                        • 179
                        I was reading another thread on the forum, is it a big help to mount the turning fin at an angle? I didn't, but now that I think about it I realize I probably should do that instead.
                        • OJ racer
                          • Dec 2007
                          • 179
                          I was just checking out the props on OSE, and they have a 3-blade that's the same width as an x435. What do you think about 3-blades on a hydro?
