Mystic C5000 1140mm new projet build
  • cyprus31
    • Jun 2011
    • 169
    #76
    After the initial setup which was a bit risky, i managed to obtain a top speed of 109.50 klm. I wasnt very happy though with the stability of the boat and also i had water linkage inside the hull. One of my water tubes failed. All fixed now.
    I strongly beleive that a pair of 3 blade props will fix the stability prop. I just placed an order from UK Props for 445/3 and 447/3
    Lets see
    • silver
      • 84
      #77
      Very fine to here the storys, still hard building but not now wich props i will order.
      The shop in the UK is the most logical to order from Belguim? ore are there more shops that can deliver props in Belguim?
      succes with the test of your new props i will follow your storys
      Silver
      • cyprus31
        • Jun 2011
        • 169
        #78
        o mThanx Silver
        this shop in UK sounds very professional to me: http://www.prop-shop.co.uk/
        Are you building also the Mystic 114 boat?
        • silver
          • 84
          #79
          Hi Syprus,
          thanks for the web-page
          I'm also building a Mystic 114 with leopard 4082-b 2200kv but its going slow, have to find some time more to build.
          if i see you and Nata2, how fast you are building its so cool.
          when i have some time i will post some pics.
          have still to bye two esc, props and batterys
          regards
          Silver
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #80
            Silver, the thing is.... if you have all the parts and know where they are going, then its a quick build. If your just looking at the hull not knowing where to start, it will take forever. I was looking at the hull all day before I got the currage to drill the first hole
            • cyprus31
              • Jun 2011
              • 169
              #81
              Take it easy Silver. If you are not an experienced builder then please ask here if you are not sure about something. Kent (nata2run) is a very helpfull guy.
              Kent maybe you can upload here the file of where the struts sit.
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1876
                #82
                I can do, but I know silver has been following my build. If there is something you need silver, measurements or idears please feel free to ask
                I can even email you templates of where to drill.
                http://forums.offshoreelectrics.com/...M-1140mm-build
                • silver
                  • 84
                  #83
                  Thanks for the support, will soon start to proseed with the building.
                  looking already months to the hull but by it self it will not finnish.
                  the templates are ok that is not the problem.
                  But i'm still not realy now where the exact position is of the engines.
                  Maybe Kent you can give me some measurements to lamminate the to motor plates?
                  I will start also a thread so you can follow how it is going in Belguim.
                  regards Silver
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    #84
                    Hi silver, I'm going to answer in your thread :)
                    • ManuelW
                      • Oct 2010
                      • 786
                      #85
                      just as a hint to all the builders of MHZ Mystic 1140's on this thread.
                      Either 2x Leopard 4074/2Y with 2150kv or Leopard 4082/1.5Y with 2200kv used on T180 ESC's and 6S 5000mAh 40 lipos or above will give you speeds around 145km/h or above with right trimming already on Octura X447's S&B. Hardly any need to prop up to something like X450/3's, as I think they are a little "too" much for the setup.
                      Best regards,
                      Manuel
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #86
                        I think X450/3's on Leo's might be instant also spinning them at 55440rpm with 4082/1.5Y with 2200kv is a bit over the top, no? you want a boat for more than 5min? I have a lot of respect for Manual, but he's a bit of a "SAW KING" LOL not in a bad way Manual....dont take it wrong.....but when Manual goes "morning boating" he brings eggs and bacon and simply puts them on the components, and kills 2 birds with 1 stone I think a "safe" setup with the Leo's may be around the 115km/h with components staying between 40c-60c degrees.
                        • ManuelW
                          • Oct 2010
                          • 786
                          #87
                          @ nata2run:
                          A 4082/1.5Y won't spin 55440rpm, expect more something like 42.500 with X447's. And I wouldn't call myself SAW king including usually cooking my lunch on my components. Even in SAW trim I expect my components to stay cool (<60°C).
                          Guess how I know that it works as posted above with the Leos - well because I tried:
                          Components were around 35°C after that run, with 5000mAh 40C instead of the used 4000mAh 40C you can expect more. If your aims are around 115km/h I'd go back using just 2x 5S 5000mAh 40C.
                          Best regards,
                          Manuel
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            #88
                            Manual I know you are getting that kind of speed, I have seen that myself. The Lucas Oil right? HPR115. It's impressive with a small setup like that. I am totally not having a go at you, but would you honestly call this a reliable safe setup? What you can do is one thing, what you recommend to others, well? I so far only see you @ 150km/h with that kind of setup.
                            Saw King is good :) what's wrong with that
                            • ManuelW
                              • Oct 2010
                              • 786
                              #89
                              Hi Nata,
                              well I'd call it quite reliable. Sure there is not that much spare room for making mistakes, but also with much more expensive components you don't have much more room for making mistakes in these speed regions (expect for setups like 2x LMT 2240/8 LK and AS 26.200 ESC's...). In Germany there are a few more who run this setup at quite the same speed.
                              As I wrote for more moderate speeds I'd use 2x 5S instead of 2x 6S because thats better in my eyes than using smaller props. With X447's speeds over 120km/h are still possible without problems.
                              The reason for my post was yours:
                              Steve here on OSE has them 450/3's, I also got them. They do look big and scary but it seems to be working will put them on my mystic when I feal good and ready to go 140+
                              My aim was to note that already with X447 you will get some serious numbers, not much need for using bigger props.
                              Best regards,
                              Manuel
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                #90
                                Originally posted by ManuelW View Post
                                Hi Nata,
                                Best regards,
                                Manuel
                                Manual,
                                Thanks for confirming!! my issue/delemma is that I now run 1717/1580 on 6s. Without bigger props or 8s I dont think I will make it over 100km/h
                                I have ordered some 1816/3 just to see how I go maybe 115km. If all goes well I might try the 450/3 maybe around 130km?
                                if its safe I could ofcause run 8s on current setup and maybe get around 130km?
