I know you'll get it dialed. Here's some thoughts :
Rudder seems long; it'll pull front down & then the front will plane up again. Boing Boing. (just a thought, may or not help to trim rudder shorter but you probably don't need that deep a rudder)
Bottom needs to be FLAT. Worked out the very same problem with other monos when the bottom had irregularities when internal component installation/epoxying sucked up the bottom. Trueing the bottom totally cured this. With the abs bottom of the Villian, this may have happened. Straightedge, bondo, sand, eucch !
FWIW on my 30" or less monos I shorten the stinger @5/8". Not sure this is involved with your situation, but just sayin...
Hang tough, You'll get it
Now you just need a scale driver.
