How many Degrees of turning
  • calcagno45
    • Mar 2008
    • 1006
    I'm building up my Cat. I'm working on the steering right now. Approximately how many degrees of rudder turning is ideal?
  • Flying Scotsman
    Fast Electric Adict!
    • 5190
    Depends on how fast you run. What hull, motor and power?
    Douggie
    • calcagno45
      • Mar 2008
      • 1006
      30" Cat, 9xl, xpower 100, cf45 prop for now, 12-16 nimh. btw its a Futaba 3305 servo (125oz/in torque)
      SO I'm guessing degrees is a matter of preference. Straight lines might want less. Oval racing might be bias to the right. sport driving might want more both ways. Did I hit the nail on the head? Or am I out in left field?
      I'll be doing more sport driving and showing off in front of the neighbors at the house on the river.
      • Flying Scotsman
        • 5190
        none of the above. Dial your boat to be straight, if your rudder is not centered you will lose power as the thrust from the rudder will reduce your power and speed. You will wish to have a small degree of rudder control as too much will end up in a boat out of control
        Douggie
        • G Doggett
          • 446
          Like most things, its a compromise.
          You dont want too much rudder angle from 'lock to lock' or the boat will be twitchy, particularly if you are a bit jerky on the controls, but you need enough angle to be able to take evasive action at times.
          I usually aim for about 20 degrees either side of centre.
          Graham.
          • calcagno45
            • Mar 2008
            • 1006
            Thanks Graham. Thats what I was looking for, a number. Appreciate it. It gives me something to start from from.
            • FRED
              • Jul 2007
              • 230
              degrees of turning
              Gentleman beat me to it. 20 degrees max.
