30" Cat Build up
  • calcagno45
    • Mar 2008
    • 1050
    30" Cat Build up
    Hey guys,
    I finally got everything in to build my 30" Cat(has standoff). I have a few question now.
    I'm using the Octura Inline Hardware kit. When I mount the kit to the standoff, when should the skeg/flex cable be position, even with the bottom of the tunnel or sponsons?
    Also I'll be running a 9xl, will I need to reinforce where the hardware is mounted? and if so how do I go about it with it being in the standoff?
    Next, I was to paint the hull over. Should I get everything munted how it like, disassemble and then paint? or should I paint the hull first?
    I'll get some pics up as soon as I can.
    Thanks for the help and please follow along with me, its my first build.
    My prop hasn't been wet in a while.
  • txboatpilot
    • Oct 2007
    • 1805
    Hey guys,
    I finally got everything in to build my 30" Cat(has standoff). I have a few question now.[/QUOTE]
    Install the hardware so that the strut bottom, is flush with the bottom of the sponsons.... Lay the hull flat on a table, set the hardware up so the bottom of the strut is level and sitting on the table.. This is a good starting piont.
    Just make a back plate out of some 1/8 ply... install it in the stand-off on the inside for support,,, Just use 20min epoxy...
    Mount up the hardware, then disassemble and then paint...
    What colors are you going to paint it??
    • calcagno45
      • Mar 2008
      • 1050
      So a small 1"x1" piece of 1/8 will do wonders in the standoff?
      As far as paint I was thinking along the lines of these colors:
      • txboatpilot
        • Oct 2007
        • 1805
        You could go to 1/4 ply for more strength.. I like your paint idea, I have 2 hulls that have Monster Energy decals...
        • Eodman
          • 1285
          I would build it first then disassembly it for the paint job! No sense doing a 1st rate paint & then slip and screw it up while finishing the build!
          A couple of issues back there was a great article on painting hulls in RCMB magazine!
          We did it with a Bang!
          Cats Are Where It's At!
          • calcagno45
            • Mar 2008
            • 1050
            Ok, I'll assemble, disassemble and then paint.
            I have some pics I'll upload to start off with.
            Another question is about the brass tube that comes with the Octura Inline hardware kit. It comes with .130 flew cable. I'm using a .150 flex cable. From trying to fit it, I assume the 7/64th brass tube is only for the .130 flex cable and not the .150?? Or I have to use the teflon liner? Can I just run the cable in the tubing?
            • calcagno45
              • Mar 2008
              • 1050
              a couple pics here:
              • blastoff
                • Apr 2008
                • 171
                Calcagno how did your build turn out ??? I just got the same hull and need tips as well.
                I am not to impressed with this ACCELLERATOR Catamaran it's kind of cheesy at best but it should make a O.K. first build. I just ordered this rudder:
