MHZ Mystic M 1140mm build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #496
    Dont chicken out and start again, m8.. use this as a learning curve to get things right !
    The 114 has the power but not thrust atm.... think props and thrust...
    Grazacind in Qld uses 448/3 on his 1717 cat ....yours has bling, his has zing !
    No no no, not chicken M8 - I have for a long time been set on the 1380mm (as you know) I want to see this as a powerhouse and I know its build right, but I want a bigger model, and use some of my heavy gear.
      Oh man,I'm speechless...
      Doc,448/3's counter?Where do I find em?
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #498
        Me too, but hard to tell wife I need another 5K boat. This way makes it easy on the other half. If I can have the same boat in a bigger model I'll be happy.
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          #499
          Heres the link - http://forums.offshoreelectrics.com/...le-1717-Motors
          • drwayne
            • 3012
            #500
            trimmed x450/3
            that 2mm makes for a big difference.
            W
              I have heard that Neu's/Castle motors like more diameter than pitch.
              • drwayne
                • 3012
                #502
                Hmm
                1518/1800 on 6S 42krpm loaded loves x447.
                1512/1800 on 6S 42 krpm loaded loves x442.
                Thus more torque more diam , more rpm more pitch.
                But there's a point when too much or too little of either and nuthn works.
                I also work on 1kw per Kg for fast. 2kw super fast.
                Wayne
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #503
                  Took her out today, new record of 119,5km/h uploading vid shortly. Props 4518/2 propshop. Nearly side flipped must have a play with stingers and COG I think I have to adjust them to more negativ to keep the nose down. Other than that she was good fun.
                  Link - http://www.youtube.com/watch?v=b3j-Z...ature=youtu.be
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    #504
                    Ok stingers are adjusted, ready for a run in the morning if weather clear. Let's get this girl up to speed before she sells.
                      Ok then I'll leave my setup opinions be for the moment and we will see the next vid.
                      Hope you get there today.
                      • Prop-a-Gator
                        • Feb 2012
                        • 168
                        #506
                        Nice video Kent. Did you run through a couple sets of batteries? That was a lot of running! Seems like enough runs to tweak the cog/stingers on site, yes/no? Good luck w/ the adjustments.
                        Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
                        • drwayne
                          • 3012
                          #507
                          Hiya
                          Sounds like motors out of sync...Can hear one spool up before the other infirst few mins before packs lose top end.
                          Nice props !
                          is your rudder sharpened ?
                          Looks like rear end is dragging... raises front.
                          Have you 600 sanded the sponson pads ?
                          c u 10:00 Sunday morning for some chilly water time !
                          attached pic is a teaser for this water in a few weeks.
                          W
                          • Rumdog
                            • 6667
                            #508
                            OHHHH! It's the big boy Genesis! Where you find those, Doc?
                            • Rumdog
                              • 6667
                              #509
                              From the last vid, it looks like the hopping is pretty level till it gets too much air in the tunnel. Maybe the props have too much lift.
                              • drwayne
                                • 3012
                                #510
                                FC imports this TFL hull , he calls it the "daytona"
                                TFL also produce decaled and filled with ALL hardware ... amusingly most the same gear FC has in his 4sale !
                                haha
                                Although their assembly was a bit rushed re shaft alignment.. easy to reset.
                                ARTR ... just add electrics .. even comes with 450/3 props !
                                Where from ?
                                Im building this one for www.rcboatbitz.com .. like having China on my doorstep !
                                Stingers are angled down.. same result ... he says 'unable to adjust '
                                W
