FC Super Daytona twin build
  • scott007
    • Feb 2012
    • 9
    #136
    Hey Bruiser The build looks great, I am about to be building my first and i'm going all out on my first build, I am waiting on boat to arrive fromthe painter which pics are posted on here from Pro Painter the boat is his latest Clean Getaway. My ? is where did you get the carbon fiber, I am looking for a small sheet to do some of the same things that you have posted here, also I like the pins you used for the hatch, where did those come from? and also what is your idea on the ESC? Sorry for all the ?s but again I am new to this and appreciate any and all advice. Thank You. Scott
    • bruiser77
      • 257
      #137
      Originally posted by Chrisg81983 View Post
      Bruiser what do you use to cut the cf it looks really neat
      I usually use a jigsaw , clamp on a level and use it as a straight edge/guide to get my cuts straight. I also have used a table saw and miter saw, but you end up wasting about 3mm of material each pass due to the blade width. That add$ up quickly. So i try not to use them unless necessary. If you use a scribe to mark your lines it makes life alot easier compaired to tape and a pencil. Then finish up the edge with a quick 80-100 grit sandpaper sanding block. Bruiser
      • bruiser77
        • 257
        #138
        That is a killer paint job Scott, love the name. is that the hull that OSE sells? I got the carbon from www.protechcomposites.com and the hatch pins from www.mhz-engines.com As far as ESC's, im using Fightercat racing 16/300 and will be mounting them in the side tunnels in front of motors. Glad to help, any questions feel free to ask, Bruiser.
        • scott007
          • Feb 2012
          • 9
          #139
          Thank You Bruiser for the info, and the compliment, I own a cleaning company and sell janitorial products so we named our big boat (Chaparral Sig 290) Clean Getaway so I carried the name on to the rc boat, the hull is a Central RC Hobbies Mystic Sport and I do belive OSE does sell CRCH boats.
          I am sure I will be leaning on you guys here in the future, Thank You. Scott
          • Chrisg81983
            • Jul 2011
            • 1585
            #140
            Ok cool thanks for the info bruiser
            • bruiser77
              • 257
              #141
              No problem Chris, garage fab all the way:) Bruiser
              • Chrisg81983
                • Jul 2011
                • 1585
                #142
                I hear that I am rite there with ya I might try my bandsaw with a real fine metal blade on it
                • bruiser77
                  • 257
                  #143
                  That would work perfect! Metal blade for sure. If I had a vertical bandsaw I would be a happy camper!
                  • Chrisg81983
                    • Jul 2011
                    • 1585
                    #144
                    I bought my self a few nice tools just for my hobbies I keep them separate from my tools I use for work as I mainly am a marble / granite fabricator but also have a construction company so tools are a necessity for me but the band saw can make life easyChris g
                    • drwayne
                      • 3012
                      #145
                      Nice build, Bruiser.
                      Browsing for ideas.. Ive MHZ135 on it's way !
                      • Espresso
                        • Jul 2011
                        • 248
                        #146
                        Post some more pics!
                        • bruiser77
                          • 257
                          #147
                          Thanks drwayne,MHZ are beautiful boats. I would like to build one of there 73" cats one day.
                          • bruiser77
                            • 257
                            #148
                            Here are a few with the sled lowers ready to be screwed in.IMG_4687.JPG IMG_4694.JPG IMG_4684.JPG
                            Got the flex shafts, 1/4" to 3/16" from OSE in the mail. In in order for me to get a snug fit on the flex saver bearing i had to make some bushings out of brass and loctite them in. Couldnt find the proper size bearings anywhere online. Not a good pic but you get the idea. IMG_4693.JPG
                            • Chrisg81983
                              • Jul 2011
                              • 1585
                              #149
                              Bruiser if you dont mind me asking what is a flex saver bearing I never heard of it thanks chris g
                              • bruiser77
                                • 257
                                #150
                                If you go to www.mhz-engines.com they sell the flex saver which is basically a bearing carrier with a nipple to lube the flex shaft that mounts on the stuffing tube. It is supposed to keep the flex from whipping around. There is a detailed pic somewhere on this thread of the flex savers. Sorry don't know how to post the link. Bruiser
