Doug, my hydro should be in OZ soon where did that turn fin come from?
Darin's Vac-U-Pickle
Ray Fuller, it's on his precision hardware page.Originally posted by andym View PostDoug, my hydro should be in OZ soon where did that turn fin come from?
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169
Your welcome,Originally posted by andym View PostThanks Doug, did anyone try the solinger harware or did all the trial boats run fullers?
We used Fullers on all the prototypes. As far as I know flyguy55 has built the first one with Solinger hardware.
IMPBA President
IMPBA 19887L CD
NAMBA 1169
I recived a PM on how the Solinger hardware set fits .
The push rod doesent line up between the servo and rudder horn with out a z bend .
The rudder horn sits on top of the rudder and is at least 1/4" too high and is too far left. Depending on what kind of push rod seal you use it takes a Z bend to line up. I also used a Heavy Duty EZ connector on the rudder connecton mounted below the horn .
It looks like it will be fine.
I mounted the bracket screws on the transom center line that offsets the strut 3/16th to the right. The strut is mounted on the left side of the bracket.
