rc catamaran
    • 7651
    I had put that on for a separate Rx pack.There is no BEC.I'm gonna fire it up tonight and try an Astroflight 207 I found while digging around for ya.Thought I may have had some old props.NOT.I'm not that concerned with money as I'd rather see it in use and help you with the FDP.
    • dannybj26
      Going fast on the 836
      • Sep 2011
      • 306
      So there's only one plug for the reciver ?
      losi scte full carbon,Hpi baja 5te,Hb tcxx
      Enforcer gator full mod 30cc
      Rico 31
        • 7651
        Oh my bad,this does have a BEC.Geez,now I can't remember why I added the spare plug.This controller is old,20 years or somewhere around there.Oh,by the way,it seems to check out fine.I'm glad.Man,its slow around here,you're only third down the list and you replied at 10:00 am.
        • dannybj26
          • Sep 2011
          • 306
          Yeah its pretty slow I've put about 7 other treads and they have gotten only about 3 replies and is it watterproof. Maybe one plug is the bec and one is the control for it ?
          Rico 31
            • 7651
            It is waterproof,advertised as and everything.It is a great controller,it was about $400.It's just for brushed motors only and I'm on full on brushless.If you want to watercool it you can add a cooling plate to it.It had one,just don't know where it got to.
            • dannybj26
              • Sep 2011
              • 306
              And around how much does it weigh ?
              Rico 31
                • 7651
                Sorry Danny this post didn't come up for me till now.ESC weighs 175 grams or 6 ounces.
                • dannybj26
                  • Sep 2011
                  • 306
                  Ok and what plugs does it have for the batts and motor ?
                  Rico 31
                    • 7651
                    Wish I would've chacked this earlier so as to move this along,I was busy mounting driveline on the Carbon Cat.What kind of plugs would you like to see on it?Don't really have any on right now.Think i've got some Deans,Traxxas(lots),Sermos and maybe a couple Astro Flight.Oh yeah, the red Tamiya in the pic is for the reverse battery pack.Yes it's got a separate reverse system inside.Don't think I ever used it.Cool option though.
                    • dannybj26
                      • Sep 2011
                      • 306
                      How does the reverse battery option work ? Sounds intresting
                      Rico 31
                        • 7651
                        It just runs a separate battery pack for reverse,then it runs like any other ESC.They used to have a hard time with polarity reversing in high amp ESC's.
                        • dannybj26
                          • Sep 2011
                          • 306
                          Ok so it runs on two battery packs 1 for reverse and 2 for foward the one for reverse works on foward also right ?
                          Rico 31
                            • 7651
                            The two packs do not run together,the reverse is a separate circuit.If I was to use it I would run a small reverse pack as you don't need much.I never use reverse in my boats anyway.Its a bad habit with flex cables,you unwind them.
                            • dannybj26
                              • Sep 2011
                              • 306
                              This boat has solid shafts and I will need 3 batteries ?
                              Rico 31
                              • dannybj26
                                • Sep 2011
                                • 306
                                and how much would you take for it ?
                                Rico 31
