Naveed's dual Toysport Tritons !
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Naveed raced NAVIGA in Great Britian. The stepped-hull Tritons with flood chambers were a common rig. For P-Mono in NAMBA, no stepped hulls, so Nav got a new no-step Triton hull to replace the Euro version. The new hull is wider and should be less twitchy.
    Toysport Tritons are absolutely gorgeous, super solid CF boats.
    First , to keep the CF theme going, I made a transom doubler from CF sheet
  • properchopper
    • 7708
    I finally found the perfect, deserving home for a Rearwheelin Randy CF motor mount that I'd been saving for such a project. To keep the CF theme going and come up with a clean, convenient mounting location for the speedy, I tapped the mount and put a CF speedy mount on top of the motor mount. ( This was a tricky move to get it perfectly located but it was worth the effort.) The motor isn't off center ; there's the flood chamber wall on one side.
    Here's the shaft to motor mockup. I used a 9/32" teflon lined shaft stepped down to 1/4" to enter the Speedmaster stinger. There's a slight bend in the stuffing tube to avoid cable whip.
    • properchopper
      • 7708
      CF servo mount, neatly tucked away but accessable
      CF battery trays; one-wrap velcro holds them in. Assymetrical due to flood chamber
