Mike's P-Limited PT Sealth pictures
  • longballlumber
    • 3417
    Hi Jim,
    I don't use straps in my P-Limited set ups. I simply by Velcro brand that already has the adhesive on the straps. One side in the boat the other side on the batteries...
    Later,
    Mike
    • longballlumber
      • 3417
      Originally posted by jcald2000 View Post
      Mike, how wide is the hull on the inside where the batteries go and how deep is it in the battery location??
      Hi Jim,
      I will try and get you some measurements. I can easily fit two 2S packs side by side. Also on the 4S packs, you can get those with in 1"-2" of the front of the inner tub and still get the canopy on.
      Later
      Mike
      • phil t
        • Feb 2010
        • 195
        Originally posted by longballlumber View Post
        Hi Jim,
        Later
        Mike
        Hey Mike, do you have a pictue of the over all layout of your boat top view?
        I need to get some batteries and a charger this winter to set one up with the UL1 motor and esc. What do you recomend? i see a duratrax 245 that has dual battery charge
        How deep would the engine well front have to be to fit those larger batteries? i may do some work on the hull so it is easier to fit motor and batteries.
        Phil Thomas
        email supersport45@aol.com
        http://www.philthomashydros.com
        • Shooter
          Team Mojo
          • Jun 2009
          • 2751
          Jim,
          Here is a photo of the straps that I use in the PT....
