5000-5500kV motors
  • obrien
    • 1320
    5000-5500kV motors
    Who makes motors in that KV range besides Neu?
  • goldendesign04
    • 210
    lehner
    Basic 5300 700 Watts @ 55 Amps 5300kv 145g
    Basic XL 5000 1300 Watts @ 125 Amps 5000kv 215g
    • SJFE
      • 4867
      Ok I have to ask. What are you putting a hot motor like that in? Is that going to be a 2-s setup?
      • Eyekandyboats
        • 1935
        i run a MEGA 5500 KV 6 pole in my N2 whiplash
        I have only ran it twice , all i can say is thank god the hull can handle the speeds
        EYEKANDYGRAPHICS
        www.rclipos.com
        • obrien
          • 1320
          Yes it will be a 2s setup for an outboard tunnel. I have the boat together right now with the ammo 2300 on 4s but the weight of the battereis is too much. So I want to go with the 5500 or so on 2s. I have a bigger tunnel that will be going to 4s once I have the money to get it together.
          • RayR
            @SiestaKey.calm
            • 1591
            John,
            You will be pulling 120 amps in the straights and 150 in the turns with a 5300KV setup turning a 36mm prop.
            Also, will the boat balance with only 2S?
            Just thought you should know.
            All the best,
            Ray
            • Eyekandyboats
              • 1935
              with my motor its a little different. I ran a CC 80 on my tunnel with my 5500 KV motor.
              EYEKANDYGRAPHICS
              www.rclipos.com
              • obrien
                • 1320
                Ray this is for the little yellow tunnel that I was running a couple weeks ago at the fun run. The 4s set up is just too much wieght in the boat for where Herb was telling me the packs should be. He had told me that 2s was all that really needed to be in the boat anyway. I just need to save up the money for a 240 and what I think will be the Neu 1512 5500 motor.
                • RayR
                  @SiestaKey.calm
                  • 1591
                  Yep, save up yer money. Herb is into "huge" amp draw stuff, it does not bother him to smoke a controller or burn up a motor. Have you picked up one of his boats? They are flyin bricks. But, gotta give it to him, he knows how to make those bricks run. Just kinda boggles my mind when you need a 240 amp controller for a 2S boat.
                  Most motors and batteries don't last very long in that environment.
                  All the best,
                  Ray
                  • Stealth Assassin
                    • 610
                    What Is the length of this hull and how many cells? 2s?
                    • obrien
                      • 1320
                      The yellow hull I was running was one oh his hulls that I put together. I actually have the mold for that hull and deck, so I am going to lay up another one, since I messed up that boat when I clamped it together and put a hook in the one sponson.
