Here are some pics of the boat.
I removed all the stock decals and there is the classic ghosted image of them which seams to happen with all the stock hulls.
You can see one of the wings is partially broken off.
I am thinking I am going to remove both of them completely and smooth out the rear deck.
The hole in the middle I believe was there so that some T nuts could be installed on the transom to hold the UL-1, it will be filled and smoother out.
Can also see the sponsons have a bunch of cracks in them which need to be smoother/filled.
The stock radio box before I cut out the plastic tray.
Another thing I did was remove the lack of flotation from the front sponsons.
They had very little white foam that was badly glued in and had broken loose so I removed it and will replace with either 2 part or some cut up pool noodles still trying to decide which one to go with.
Beautiful lake!
I love the vid, thanks for posting!
