32" FC Rivercat build with twins project
  • HYDROJERRY
    • Jan 2010
    • 2709
    #106
    well if it runs as good as it launches it should fly!!!
    • JPriami
      N4FOX
      • 1711
      #107
      Finally figured out how I wanted my rudder servo mounted. I knew I wanted it centered somehow. A friend of mine LarrysDrifter gave me the inspiration on mounting it this way. But I did mine a little different. I was able to take my stock ekos mount and flip it upside down and trim a little off the edge and it worked great. Got that in and my 440 push rod made up.
      I also did some trimming on the front lip where the batteries go in so it's easier to get them in and out.
      Tomorrow I'll try and mount esc tray and maybe battery trays. Maybe even run some cooling lines.
      • JackBlack26
        • May 2007
        • 904
        #108
        What is that black material you put inside the hull? Doesn't look like CF, but looks good.
        • JPriami
          N4FOX
          • 1711
          #109
          Enamel paint. I sanded it a little then primed it black. Then sanded it again and put a finish coat of gloss enamel on. Since I just laid up extra glass cloth and resin in areas for added strength before the build & all the glassing in the motor mounts and stiffing up transom area etc. Painting it helps make it all look more uniform. And will be a little more appealing to the eyes with the black, red & silver colors that will be inside. I brought it to work with me today so it could sit out in the sun a cure.
          • JPriami
            N4FOX
            • 1711
            #110
            Routing lines and positioning things.
            • Gimp
              I am the Stig
              • 547
              #111
              Man that puppy's packed! Looking good though. Any ideas on paint scheme?
              -Fighter Cat Racing-
              • LarrysDrifter
                Big Booty Daddy
                • 3416
                #112
                Looks very good. Your a fine builder. Now the rest of your boats should be built, not bought.
                • JPriami
                  N4FOX
                  • 1711
                  #113
                  Yeah I have already called in my paint to my friends at the auto body paint supply. Picking it up tomorrow. It's going to be a 6th generation corvette color called velocity yellow and then turn into black on the back part. White belly. Might even throw some CF graphics in the back somewhere. All the graphics are going to be corvette 6th gen emblems and racing decals from the C6R race cars. It's gonna look good I'm sure. Jeffs working with me on the graphics I'll need. Once I get it painted and graphics in I'll clear over it all.
                  • JPriami
                    N4FOX
                    • 1711
                    #114
                    Thanks Larry. I've about had it with buying RTR crap and fixing it up. It's nice to do it on your own
                    • JPriami
                      N4FOX
                      • 1711
                      #115
                      Thanks for these Ben. Found a sweet spot for them inside too.
                      • Boaterguy
                        • 1779
                        #116
                        looks like it's painted right on!
                        would be sweet if you could anodize like that.
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #117
                          That came out really nice! Ching Bling. =)
                          • JPriami
                            N4FOX
                            • 1711
                            #118
                            Got the velocity yellow sprayed today after prepping the hull last night. Got 2 more colors to do still. But nothing to do but watch paint dry for days now. Maybe I'll take the sailboat out since it's windy.
                            • Gimp
                              I am the Stig
                              • 547
                              #119
                              This is gonna look sweet........for a Chevy scheme lol.
                              After seing your theme ideas, I was thinking about doing Ford GT theme for my FC Daytona. Can't decide between that or a Kevin Harvick Budweiser car scheme.
                              • JPriami
                                N4FOX
                                • 1711
                                #120
                                Ford gt would be sweet.
