neewbie boat build?
  • stahlm004443
    • 86
    neewbie boat build?
    hi there,
    im new to this forum and relatively new to boats. i have had a few rc cars and planes but now i want to try my luck with building a brushless speedboat.
    i already know what hull i will be using which is:
    these are all the electronics i will be using:
    motor - http://www.hobbycity.com/hobbycity/s...idProduct=2078
    esc - http://www.hobbycity.com/hobbycity/s...idProduct=4313
    battery - http://www.hobbycity.com/hobbycity/s...idProduct=5469
    any help would be great, and im not sure if that setup would work? can the esc handle the amps from the lipo? is the motor good?
    thanks
    matt
  • kin
    • 55
    its a nice hull , but no offence i dun think it be for fast runs , why noy check out other hulls or try rtr sv27 like mine!! lol
    ~known is a droplet, unknown is the ocean~
    • stahlm004443
      • 86
      well to start with i dont have much money as im only 15. and i dont realy want speed runs i was just thinking that if im gona buy a motor i might aswell buy a brushless one because there the same price as brushed.
      kin, do you know if the battery, motor and esc would work togeather?
      thanks
      • kin
        • 55
        thanks
        oh ok~ than i`ll say wecome to the boating world ,, they should work just fine but dun take my words on it , let some experts here give u some sound advice too before u make the purchase . many guys here r really frenly and will give u thier humble opinion ...
        • stahlm004443
          • 86
          ok. i think im going to order the hull tonight and i will wait on some more advise with the electronics. thanks
          anyone else know anymore, i dont have a clue i new to brushless lol
          thanks
          • domwilson
            • 4412
            Welcome to the board. Looking at what you're thinking, I don't think you'll be very happy with this setup. It's almost $175.00 USD. That motor will burn up the ESC quickly. You may want to look to Ebay for a used SV27. You may be happier with that for the same amount of money. Plus you'll get the hardware and radio which may even be cheaper in the short and long run.
            Government Moto:
            • stahlm004443
              • 86
              i wont come to that much. oh and btw i live in england. it will come to about £60 GBP which is about $120 USD
              what about this esc??
              thanks
              • domwilson
                • 4412
                With this ESC it comes out to almost $170.00 USD.
                That's not including a radio and other support parts. Throw in a cheap radio and you're at about $215.00. A bit pricey for a plastic hull boat. But the ultimate choice is yours. But I do think you'll need at least an 80 amp ESC. Looking at the hull specs. That's designed for a 400 size motor. The Feigao is larger at a 540 size.
                Government Moto:
                • stahlm004443
                  • 86
                  so are you saying that it wont work at all with the feigao 540 motor? i can get a bigger esc.
                  • stahlm004443
                    • 86
                    ok ive changed my mind im gonna go with this motor:
                    im assuming that i can now use this esc? please tell me if its too small
                    thanks
                    • Rex R
                      • 1007
                      as long as you don't get crazy with your prop choice that motor/esc combo should work*...the battery on the other hand... if you ran 2 of those battery packs in parallel (2s2p), I'm thinking that ought to provide enough margin to avoid damaging the lipos
                      *that 1st motor would have been way to 'hot' for that size hull and likely would have blown that 18 amp esc on the 1st application of throttle.
                      edit
                      ooops. that esc isn't rated for 2s Lipo's, its rated for 13-18v(but the amp rating is about right...if you got a motor rated at approx 1500kv and ran those packs in series (4s) you could use that esc )
                      • stahlm004443
                        • 86
                        ok so i need a bigger battery pack? what about this one:
                        http://cgi.ebay.co.uk/11-1v-2200mAh-...QQcmdZViewItem
                        • Rex R
                          • 1007
                          to use that pack (3s,11.1v nominal) you would want a motor more like this one http://www.hobbycity.com/hobbycity/s...idProduct=4205 you want to keep your output rpm down around 20000 rpm(25k max)
                          • stahlm004443
                            • 86
                            ok so can i use any motor between 1500kv and 2000kv?
                            • stahlm004443
                              • 86
                              ok lets make this simple! im going to use this motor:
                              and this battery:
                              seing as i dont have a clue as to all this stuff could someone please show me the cheapest esc i can use that would work with the battery and motor. preferably from www.hobbycity.com
                              thanks again
                              matt
