scorpion daytona 37
  • bruiser77
    • 241
    scorpion daytona 37
    My boat arrived friday in perfect condition with everything i ordered from benjamin at fightercatracing.com I am very pleased with the boat and hardware. i got a chance to do a little work on it this weekend. Mounted the stingers, rudder and made some rough templates for the bulkead, transom plates and motor mounts. Waiting on the carbon fiber cloth, 1mm and 2mm sheets to arrive this thursday so i can have everything i need to get underway with the build. Im using the fightercat rudder, stingers, .187 wire drives, cooling blocks, 80hv esc's and bec's. Going to run the boat with Scorpion 3026 1600kv outrunners on 6 cell 5000mah 40c lipos. Purchased some x442's CR and 2 x447's CR.boat 5.jpgboat 1.jpgboat 2.jpgboat 3.jpgboat 4.jpg Going to make sleds for the batteries and an electronics box out of CF as well. This is my first twin build so any suggestions and advice would really help. Thanks again, Charles
  • bruiser77
    • 241
    Got the carbon fiber in the mail today! So i got start to work this afternoon and got the bulkhead, motor mounts and transom plates cut out. Gotta do some fine tuning and sanding due to the fact that i made the templates before i had the cloth in the hull. Laid cloth for the first time and am pretty happy with the results. took a little time in prep, but was worth it. Still need to finish the sleds and electronics cover but those can wait till everything else is installed. more work tomorrow. thanks
    • jasoncyclone
      • Jun 2011
      • 475
      Very nice build so far!!! You should make a couple more sets of the bulkheads and sell a set to me!!!! LOL...
      Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
      • bruiser77
        • 241
        Thanks jason! Finally a reply! Half price on the bulkheah for another california boy!
        • carlcisneros
          • Jan 2010
          • 1218
          make sure when you program the ESC's that you have the Fly sky radio throttle channel REVERSED.
          Which FS radio is it? GT2, GT3 or GT3B?
          • LarrysDrifter
            Big Booty Daddy
            • 3278
            My suggestion is a pvc boat stand. They are a big help during the build, as well as storage and transportation, obviously. Nice build too. Looking good. Is there a video coming when its done?
            • bruiser77
              • 241
              it's a gt3b controller. Ya, I had some trouble setting it up in my other boat. Throttle and abs braking setup threw me for a loop. Eventually figured it out and it worked great. Awesome controller for the price!
              • bruiser77
                • 241
                thanks for the kind words. I really need to make a run to home depot for PVC pipe asap. I will get video as soon as it touches water for the first time! Hopefully sometime next week!
                • bruiser77
                  • 241
                  IMG_3944.jpgIMG_3934.jpgGot some more work done last night. Made some stinger shims out of 2mm carbon fiber to try and get the transom as close to square as possible. This will help with trim of the stingers and the angle of the drive shafts. Finished up the motor mounts and did an early moch up to make sure everything was snug. Hoping to get the stinger in and motors mounted by the end of the night. Also got the transom plates and bulkhead set. Next step for now is the rudder plate and install. thanks for looking.
                  • JEDNJONES
                    • Apr 2010
                    • 134
                    Nice looking build. Im doing a 37 CF Daytona as well.
                    Jerry
                    Fountain KOS P1, Formula Fastech, 37 Fightercat Daytona CF twin
                    Pulled by Slash 4x4 tow vehical
                    • bruiser77
                      • 241
                      Thanks Jerry! CF daytona's are sexy boats for sure! Cant wait to see how the daytona performs in person! getting anxious! Good luck with your build. thanks again.
                      • bruiser77
                        • 241
                        More progress over the weekend. IMG_3967.jpgIMG_3966.jpgIMG_3965.jpgIMG_3964.jpgIMG_3963.jpg
                        • bruiser77
                          • 241
                          IMG_3968.jpgIMG_3969.jpgIMG_3970.jpgIMG_3971.jpgworked on the electronics cover this afternoon and made a little progress with it. got the stuffing tubes and wire drives finished. After the cover is installed its on to wiring and prop work!
                          • Jacked1
                            • Jun 2010
                            • 772
                            Nice! Those scorpions should get it close to 70+mph with the 447's!
                            • bruiser77
                              • 241
                              Thats wjhat im shooting for! i really hope i get close! If not i will just have to step up the # of cells!
