Here is the inside with everything plumbed. Water goes from pickup to ESC, to motor and then out the top. On my old boat I went out the back and could never tell if it was flowing as I drove it. Hopefully I will get a visible stream.
I used a $4 plastic rudder setup from some RTR boat. Worked well with the old boat. Remember I put together about 15 of these boat kits so $$$ was important. Hole was there for the homemade water pickup.
Battery is VERY tight. In fact I really cannot move it. Tucks under the hatch mating surfaces and the aluminum mount has a little give to push it up. Ended up with the balance point at 28%. Could not push the motor ahead anymore. The wiring comes out the end and does not bend easily. Different than the old brushed motor.
