I will post pictures, and add details as time permits.
Im a busy bloke !
Bought mid June from Australian importer.
Had slight transit damage to tip one sponson which I knew of before buy, but the sh ite gel on cowl was a disappointment.
Intent is as follows
twin 1518/1800 swapshop OSE
HRC 1518(rib) coolers OSE store
6S2P shared, or 6S1P to each single.. finished with 6S1P to each
200+A per side finished with 2 x SF240HV swapshop OSE
stingers 2x1/4 modded to 3/16 full rollers with oil feeds eBay and local bearing supply
ext LVC dimension engineering from OSE
ext UBEC Turnigy 3S10-15A HC at HK
L&R hughey 3/16 flex OSE store
Fresh from box
Engine mounts 75x50x4mm 90' drilled to suit.
a basic shape first up
And then the shape for sponson insets
And next, the sh it gel finish on cowl
at top centre this pic is the gel issue.
Im a busy bloke !
Fresh from box
