VS-1 FE Build
  • Pete32200
    • 281
    VS-1 FE Build
    I Picked up a new VS-1 Hull from Kintec racing Saturday and started my FE conversion, I already had a K&B 8686 Drive and 5190 adjustable mount. I knew I wanted everything as low in the hull as possible and I wanted alot of adjustability for and aft for the 4s Lipo, I plan on running the steering servo in the back. I need to pick up some plywood to continue any further but here is where I am at now.
    VS1 FE - UL-1 - Motley Crew - Miss Geico - Kintec Prince - Rio 51z - 1/16 Summit - 1/10 Summit - Ken Block Rally - Kyle Busch Truck - Losi Mini SCT - BL E-MAXX - Assoc FT SC10 - Wild Willy - Clodbuster - Sand Scorcher......
  • Pete32200
    • 281
    This is the K&B mount and drive unit
    • siberianhusky
      • Dec 2009
      • 2206
      I'd mount the servo and rx right at the front, use a pull/pull cable system, try to keep the mass of the battery as close to the cg of the boat as possible.
      Cut down the lower unit also, no need for the exhaust portion, saves a lot of weight as well.
      • Pete32200
        • 281
        I went up to the Kintec Racing World Headquarters and picked up a bunch of parts to finish the build.....Here is where I am at right now.
        • Pete32200
          • 281
          I couldn't decide between the VS-1 or UL-1 so.......
          • egneg
            • 4759
            My VS-1 has the servo in the back and the lipo in the front - does better than 51 mph and is quite stable. I am using a stock K&B outboard with a Prather 215 prop and a F-8XL - T-120.
            IMPBA 20481S D-12
            • Pete32200
              • 281
              I am pretty pleased with it set up with the servo in the back, I never liked the cable set-ups anyway, I am running a UL-1 2030kv motor with a 90amp Seaking and a 42 x 55 aquacraft prop. I had it in the water again this morning and I love it. I do have to run the lipo as far forward as possible to keep the nose down.
              • Pete32200
                • 281
                A few more pics
                I plan on cutting down exhaust section of the outdrive but I need to come up with another water pickup first
                • egneg
                  • 4759
                  I left the one I have stock ... just in case - runs just fine.
                  IMPBA 20481S D-12
                  • Pete32200
                    • 281
                    I ran it again this afternoon down at the Kintec racing testing site and it works awesome so I think I will leave mine stock also.
                    The only time I had any trouble was when I hit a large fish that jumped out of the water in front of it !!!!
                    • Stinger9D9
                      • Jun 2007
                      • 378
                      Hey Pete,
                      Great build thread. Planning on doing the same thing myself in a month or so. One question though, when you cut out the foam to get the battery box nice and low in the hull, did you beef up the bottom (double up on the plywood or something) to strengthen things or did you just leave the existing plywood forming the underside of the hull as the bottom of the box?
                      • Pete32200
                        • 281
                        I just brushed on a layer of epoxy to help add some strength and seal it but it probably didn't need it.
                        • siberianhusky
                          • Dec 2009
                          • 2206
                          Just picked up a VS on the weekend, thinking about joining the front and back plate on the bottom, bit of strength and remove the little step at the back for a bit less drag.
                          Anybody think a bit of 1/64 ply on the running surface of the stumble blocks would change things? Just a bit of added protection for the balsa from floating crap.
                          Would you mind measuring the height of the motor adapter? I like that setup a lot but I have an idea for a water cooled mount I'd like to try, figure I might as well start with an idea that can use a widely available factory collet.
                          Excited about this one, a nice step up from the HotShot I currently have.
                          Thanks
