my first scratch 38` cat built
  • 08gtrking
    • 91
    Well i have already almost finished this build, sense the site i posted the build on (link) is kinda dead i decided to post it here with pics of current progress , i have already ordered the hardware(link) and i want to start to order motor etc.. i would appreciate feed back of my set up for 60 mph+ set up
    motor 4082 1500kv
    esc t180
    batts 3`s series for 6`s
    prop going to start with a x445
    hardware http://cgi.ebay.com/sliver-110mm-rud...item20b7c9b439
    Speed - Electric - my First scratch build - First off i want to say thanks to MaxCorvette for the plans and SV27dayton, KD0EM,and everyone else i left out for the help.I have just finished cutting all the balsa wood its 1/8 inch the boats length is 36inches and im not sure what to do next before i epoxy the stringers
  • Boaterguy
    • 1760
    I think the setup is good, KV may be a little high for 6S, but it's gonna be nice.
    • johnson22456
      Counting down the days...
      • 218
      The kv is fine. That leopard will rock in that boat. Larrys h&m drifter with that same motor was in the 60's running around a x447 or x450, but your smart to start smaller. I also love the 180 speedos, but disable the bec if your gonna run it on 6s. You should have a nice reliable setup there.
      Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
      • LarrysDrifter
        Big Booty Daddy
        • 3278
        Thanks Eric. I ran an X445 to start and was at 62mph and very cool temps. Great set up for your cat. Again, another misleading comment by an inexperienced member.( Not Johnson ).
        • LarrysDrifter
          Big Booty Daddy
          • 3278
          Set the center of gravity to 30% and adjust from there. You have the perfect combo to meet and exceed your speed goal.
          • 08gtrking
            • 91
            ok thank you guys for replying
            • 08gtrking
              • 91
              when you say adjust from a 30% of center of gravity means to adjust every thing inside to balance the boat from 30%? sorry for the dum question
              • Boaterguy
                • 1760
                It means he has it currently set at 30% from the transom. He will adjust depending on the ride attitude of the boat.
                • johnson22456
                  • 218
                  You will want to measure from the sponson transom. 30% of 38" = 11.4". Should be a good place to start.
                  • 08gtrking
                    • 91
                    ok i understand now ,well im going to order batts and motor etc.. in about 2 weeks ,this week im going to be sanding the boat down so i can primer it (seal) ,and im gong to create a mold so i can make fiberglass version.
                    • 08gtrking
                      • 91
                      ok i recieved the hardware today shipping was pretty fast but when i put the flex shaft through the shaft holder it hits the rudder looks like a 1/4 shaft instead of a 3/16 and is too long , i contacted the seller lets see what he replys
                      • Rumdog
                        • 6453
                        Loosen the set screw on the drive dog and slide it towards the threaded end. Also be sure to grind a small flat on the prop shaft where the set screw will seat.
                        • Jacked1
                          • Jun 2010
                          • 772
                          The strut is in there backwards, the tapered end should point toward the front of the boat and that should fix the clearance problem. But that is weird they would send you a 1/4in setup?
                          And good job on the hull!
                          • 08gtrking
                            • 91
                            [QUOTE=Jacked1;334849]The strut is in there backwards, the tapered end should point toward the front of the boat and that should fix the clearance problem. But that is weird they would send you a 1/4in setup?
                            And good job on the hull![/QUOTE
                            i feel so dum right now i ,i fliped the strut over and fits perfect and i mesearued the flex shaft and it is the 3/16 thank you sooooo much !!
                            • Boaterguy
                              • 1760
                              Don't worry, I've seen more than just you do it, I would have if I wasn't on a forum and read multiple builds.
