propeller help please !!!!
  • Eodman
    • 1285
    OK I got a little play money & I want to start ordering for my new toy!
    SJFE you recommended quite a few different props which one should I start with?
    I will be ordering the 8XL's, Hydra 120"s, what prop would be a good start point?
    Also would like to order a couple of different carbon fiber props to get a feel for how the different pitches perform! What carbon props are comparable to the metal prop you guys recommend? I would like to order props above and below the metal one!
    One last question SJ are your props counter rotating
    Ups tracking says my toy should arrive today!!!!
    We did it with a Bang!
    Cats Are Where It's At!
  • SJFE
    • 4867
    Dude I don't have a twin hull so I am not of much use to ya. Yes counter rotation use the K series cf propps to test. Start with the 40 & 42. Be carful with heat 30 seconds on the water tops then check. More later I'm workin :).
    • robby76
      • 207
      i don't know what type hull you will be running, but my experience with CF props were they flexed reducing speed. true the amp draw was around 20 amp different than the brass props but here again gain in speed was over 10mph. my twin cat props run inboard ( cw ccw ). i found abc props offer a large selection of 3 bladed props starting in the 38mm on up.
      another tool to use is the FE calc.
      how i use it is whatever combination i choose to use, i print it and write down the actual results in ink using GPS, watts up meter, and a discription to how it performed.
      just my 2 cents here.
      • Eodman
        • 1285
        Thanks Robbie, I don't plan on staying with CF props just the first few runs while I get use to the hull handling & shakedown runs!
        I just picked up a Toysport Twin Jolly from Wicked ... same hull as the one Steven has on his site!
