hk genesis hull what motor
  • Driggs
    • Mar 2010
    • 69
    I came across a hk genesis hull today, could someone suggest a cheap setup that I could use with 6 cells to get this thing hauling butt?
  • HYDROJERRY
    • Jan 2010
    • 2503
    the factory stuff runs ok!!!! this boat has been done many times by many different people i would recomend you go to the top off the page and use the search,,for genesis and you will find many threads off many different setups that work realy well in it as for me im still runing it stock with 2x2s 40c 5000 lipos hitting around 34mph all factory,,,good enough for me wright now..
    • Driggs
      • Mar 2010
      • 69
      Thanks ill search it, I don't know what was in it stock, I only have the hull
      • martno1fan
        • 238
        How about one of these?,i plan on using one in my new 38" cat once i get the moulds finished.
        Mart
        http://www.hobbyking.com/hobbyking/s...dProduct=11980
        • martin
          • 2869
          That Turnigy T 600 outrunner 1400kv is a very powerfull motor & will swing big props so a good choice. Its still a cheap motor at $60 but they have doubled in price from a couple of weeks ago when i looked at getting one at $30. Martin.
          • Driggs
            • Mar 2010
            • 69
            I was thinking this one , but I have no.idea what I'm doing, prop and stuff, http://http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=15234 on 6 cell ?
            • Make-a-Wake
              FE Rules!
              • 5554
              I think 6 cells may be a tad high for that motor(HK 3674 1660kv), you may want to consider this motor OSE is now offering. Its a 4 pole 4074, try it in the 3Y version on 6s:
              http://www.offshoreelectrics.com/pro...prod=keda-4074
              • martno1fan
                • 238
                Yes just shows they read this forum as i got two of the 880 kv ones for one of my Apaches a cpl months ago and noticed the price leap.Still very cheap as you say and they are powerfull,a friend has two in one of my 58 hulls and its pretty fast for a big boat at over 35 mph so one with higher kv in a small cat should rip.
                Mart
                • Alfa Spirit
                  • 2131
                  6S is ok for the Genesis with a single motor. Choose a 1500kV motor, LEOPARD 4082 2Y 1500 Kv/rpm per volt or 4D 1450 Kv/rpm per volt
