Summer Project: FE Hydro
  • CHUD
    • 497
    yes it's a NQD,and the day me and HJ took the elom and my hydro out the nqd would run as fast as the elom,but my boat ran hotter the 60 amp should be a 120 I would think,and I didn't put the fin on tell last,I should have put it on first,I will get up somemore pic of the in side mybe it would help you out,
    • nosreme722
      • May 2011
      • 181
      Yeah, thatd be great. Some pics of the turn fin and transom would be fantastic. Thanks!
      • HYDROJERRY
        • Jan 2010
        • 2503
        Maybe not as fast as the 41mph Elam but getting there!!!!!LOL
        • CHUD
          • 497
          Will just have to drop the gps in this weekend bro and get that good vid I no Diesel want's to see that one
          • CHUD
            • 497
            #35
            O,K This is the turn fin from OSE its a Aquacraft grimracer 15/18 Hydro turn fin I think it might be a little to big ,I would like to try a ul/1 it seem's to have alot of drag with the 15/18 ,hope this help's out,I had to drill a hole above the bracket and after the screw's where in ,fill the hole with a lot of one min apoxy, to apoxy the back of the scew's
            • nosreme722
              • May 2011
              • 181
              #36
              So maybe this: http://www.offshoreelectrics.com/pro...qub9539&cat=67
              or this: http://www.offshoreelectrics.com/pro...od=dh-aqub9515
              Also could you get a pic of your transom? Thatd help too. Thanks.
              • CHUD
                • 497
                #37
                That's it I have the 16.99 one,wish I would have maybe put a block of wood inside before I epoxyed the hull together, my brother hydrojerry gave me the strut @ flexshaft so I'm not sure what it is,also the rudder,I did get to put a strip of basawood in the tail for the rudder @ strut bracket's,worked out good, another pic for ya,
                • nosreme722
                  • May 2011
                  • 181
                  #38
                  Alright i'll pick up the first one see how that works out. Looks like some simple hardware, ill look at some speedmaster struts, etc. I'll prob do 078 wire drive and put the motor in the cockpit or whatever. Thanks alot pics helped! Hope mine turns out as well as yours did.
                  • nosreme722
                    • May 2011
                    • 181
                    #39
                    Alright so i wanna make sure im getting the right stuff before i make some orders..
                    wire drive - 3/16 x .078
                    motor mount
                    anything cheaper than speedmaster, the price isnt to bad though
                    http://www.offshoreelectrics.com/pro...d=ros-21-strut
                    possilby the "3 inch Rudder w/ water pickup" or "4 inch Rudder w/ water pickup"
                    and what about stuffing tube etc? Any advice?
                    • wparsons
                      • 461
                      #40
                      You'll want to make the stuffing tube as straight as possible with as gradual of a bend as possible since you're running the wire drive. You might have to run the motor really far forward to make the bend gradual enough.
                      Light travels faster than sound, so people may appear to be bright until you hear them speak.
                      • nosreme722
                        • May 2011
                        • 181
                        #41
                        Yeah i planned on putting the motor up in the cockpit area.
                        • sailr
                          • Nov 2007
                          • 6924
                          #42
                          Aren't those the same as he already has? I believe so.
                          Mini Cat Racing USA
                          www.minicatracingusa.com
                          • nosreme722
                            • May 2011
                            • 181
                            #43
                            what..?
                            • sailr
                              • Nov 2007
                              • 6924
                              #44
                              HE asked if the turn fin he had was too big and then you provided links to the SAME turn fin. I just said isn't that the same as he already has?
                              Mini Cat Racing USA
                              • nosreme722
                                • May 2011
                                • 181
                                #45
                                oh yeah, sorry just didnt understand. I dont know if it will make much of a difference and may provide more turning ability but, if he said its a little too big then maybe its a little to big. Anyone got a link to a better one?
                                Chud suggested the ul-1 fin
                                "UL-1 2mm Aquacraft Fin"
                                P.S. hey Chud when you ganna get that video up!
