55" Quad or Triple Cigarette Boat
  • Jacked1
    • Jun 2010
    • 772
    #46
    I got some big caps no spark resistors and hooked them up with the connectors thanks to Ben at Fightercat. All of the esc's initialized and now I am going to start sealing up the box.
    The old esc that I put in oil seems to not have changed in any way after 5 days. So I am very optimistic about the entire thing right now. All I have left now is some hardware and servo mounting stuff and that is the easiest part! I will hopefully get it in the water this weekend but probably not until the next weekend since the lakehouse is getting resided this weekend.
    If this goes well I am going to change from a gear drive in my 47incher to inline motors and trade the 100amp castle esc's I have in there for some 80amp hv's. ( I have the 880kv T600 in that boat.) And I am thinking two at full power will perform close to the same as a Leo5692.
    Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
    • Punisher 67
      Ignore list member #67
      • 1481
      #47
      Originally posted by Jacked1 View Post
      Thank you Peter! I can only hope it turns out half as nice as your big Stealth or one of your Snipers!
      I am sure that it will , I have to admire your willingness and potential sacrifice to try something new
      Necessity is the mother of invention.............
      • Jacked1
        • Jun 2010
        • 772
        #48
        Thanks again Peter! It keeps me interested in building.
        I haven't been this excited for a boat since I got my Villain when I was 10.
        • Jacked1
          • Jun 2010
          • 772
          #49
          I have been thinking about what to do with water-cooling, there are 4 motors and 2 esc tubes to cool. I initially thought of having 2 pickups (one for two motors each) plus one from the rudder (for the esc's). Instead I am thinking of doing something kinda different and simple which would be very fitting for this boat.
          I think I am going to use a pretty large piece of k&s tubing for the water pickup and then split it into 4 different streams for each motor. This large tubing would allow for more waterflow but make it look a little less cluttered at the transom and then the water pickup in the rudder to cool the esc box. Then I would take an even larger piece of tubing and have a large water outlet and make it look like an exaust pipe out the back of the transom.
          • Jacked1
            • Jun 2010
            • 772
            #50
            Gold and silver strut! (aluminum and brass )
            • Boaterguy
              • 1760
              #51
              gonna have to keep polishing up that brass, but it looks great at the moment!
              • Jacked1
                • Jun 2010
                • 772
                #52
                Hahah yea! It only has to look good untill I am done with the build then it can get ugly because no one will see it up close!
                And here is the box with the acrylic! I need to trim it a little and get some RTV silicone to seal it up tomorrow!
                • Jacked1
                  • Jun 2010
                  • 772
                  #53
                  Everything is completed other than the steering part of the boat (mounting the rudder and stearing servo) and the box being sealed. I went ahead and added two inlet/outlets on the top of the acrylic for the box so there will be a place to add or remove oil or a place for the oil to expand to when it gets warmer.
                  On a different note, while working with ways to collect regenerative power from beaking electric actuator motors where I work, We came up with an idea on how to make a lightweight and simple electrical storage system that I want to apply to boats that would cause a type of "Electrical NOS" for saw boats. In short, it would allow a boat running on 2s and 200amps to deliver 3 times the power to the motor for about 3 seconds and only add about 180 grams to the boat.
                  • Boaterguy
                    • 1760
                    #54
                    That's interesting, how does it work?
                    • Jacked1
                      • Jun 2010
                      • 772
                      #55
                      I am not 100% sure I am allowed to say the details since it is for the government and may be part of the F35 eventually. But I can say it is a similar concept to how F1 cars use breaking to spin flywheels that they use for acceleration after they make a turn but it is done electrically and is much lighter. I think Porshe is comming out with something similar for their production cars that would allow an extra 100hp or so for a short (10 second?) period of time for acceleration.
                      But since it is electrical and no flywheel is involved you can have the extra power for a long period of time. And it would be "pre-charged" for use in a boat since it would be hard to get regeneration from a propeller.
                      • Boaterguy
                        • 1760
                        #56
                        So it's one time and then recharges, I'm sure it could be integrated into the shaft somehow.
                        • Jacked1
                          • Jun 2010
                          • 772
                          #57
                          BEEEFY!!!!
                          All 1/8in aluminum rudder brack-et.
                          • Boaterguy
                            • 1760
                            #58
                            that thing aint comin off!
                            • Jacked1
                              • Jun 2010
                              • 772
                              #59
                              WELLLLLL The motors and esc's are in the boat and if if were any tighter I would have to scrap the esc box! They are programed and set up to all spin the same direction. The rudder is on and now I am waiting on the radio I recently ordered. I decided to switch from all my 400 individual radios laying around to a fancy pants one with a 10 model memory.
                              POOSAY 007.jpgPOOSAY 006.jpg <--Yellow tubes are for inlet water and the white are for output water.
                              • d3lap
                                • Aug 2011
                                • 45
                                #60
                                This thing is coming along real nicely! its going to have a whole bunch of power to it when your done!
                                Losi 8T-e 5s/1518/MMP/645mg
                                Cat 30" build In progress...
