56" Performance International Fountain Build
  • Jacked1
    • Jun 2010
    • 787
    I am excited to see how fast it winds up going and what the run times will be!
    Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
    • b.mcdaniel.2009
      • 1872
      Little up date here....Motor mount and Jacket came yesterday from Williams Racing. They both look great but still waiting for my CF. Tracking says friday...........And my other rudder assembly will be here friday also.
      ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
      • b.mcdaniel.2009
        • 1872
        Another update. Did some Carbon fiber work today. Layed the hull, hatch and most of the wood pieces I cut. I didn't think it turned out to bad for my first time. Also bent the stuffing tube and its ready to installed. The other rudder and some odds and ends parts should be here tuesday, and test runs by the weekend.
        • crrcboatz
          • Jan 2009
          • 1103
          VERY NICE WORK!!!
          Curt
          • b.mcdaniel.2009
            • 1872
            Originally posted by crrcboatz View Post
            VERY NICE WORK!!!
            Curt
            Thanks Curt.
            Wanted to add I'll be using a larger lenth servo arm and the picture of stuffing tube with the flex cable hitting the side will be alighned properly.
            • b.mcdaniel.2009
              • 1872
              Did a little more CF work last night. Here's my idea for the hole set up. Any suggestions?
              • m4a1usr
                Fast Electric Addict
                • 2036
                If those packs are going to be dedicated to that hull I would put the packs (wire side) facing each other. And keep the wires as short as possible on the battery side. I know its tough to cut wire, especially lipos, makes my common sense want to reject some of the do's and donts. Actually what I have been doing is to keep the pack wires as long as possible, but shorten my esc batt side wires. Because I can solder batt leads on most if not all speedos.
                With all of that said, the old rule about keeping wires short in big power systems is something to be on top of. Also if you dont have a cap bank installed on the esc, you might consider one. Its a little extra insurance for not a lot of money. Are you going with 8mm bullets?
                John
                Change is the one Constant
                • crrcboatz
                  • Jan 2009
                  • 1103
                  Hey check the CG with the batteries in it as u have them laid out. Do the old "broomstick" method or similar methods. Reason, you have done such a great job with the CF would be a shame to epoxy down stuff and then move later.
                  When I build a boat I check cg as I build because we forget the little things that add wt as we go along. For instance, the epoxy you needed to put the cf cloth down. Takes just a minute and pays GREAT dividends. Big boats are as sensitive to cg as others. Any boat going 50+mph the cg will show up immediately if off. Then to compensate one must either move stuff or mess with the transom setup.
                  • b.mcdaniel.2009
                    • 1872
                    John
                    John, I do use those packs in different hulls so I really dont want to shorten the leads but how short are you talking with the esc batterys leads. I can do that because the esc is dedicated to the Fountain hull. Yes I will be using 8mm bullets motor and esc side and 6.5mm batterys side.
                    I have this cap bank that was on the esc before It went to Castle's repair shop, but when I received it back there wasn't any leads to use it again. Below is a picture of the cap bank John. There's 5 caps total........
                    • b.mcdaniel.2009
                      • 1872
                      With everything inside the hull except the larger servo arm and some velcro the COG is 29%. Do you think thats a good place to start Curt?
                      • crrcboatz
                        • Jan 2009
                        • 1103
                        Curt
                        • b.mcdaniel.2009
                          • 1872
                          Did a little more work on the hull today . Everything is ready to be permanetly mounted, just a little nervious...I think I've checked everything like 6 times now . Making a call to Castle tomorrow and see how short I can make the battery leads. Any comments?
                            • 9481
                            Good job on the CF work bro!
                            • b.mcdaniel.2009
                              • 1872
                              Thanks Not bad for the first time If I dont say so myself LOL!
                              • martno1fan
                                • Jan 2011
                                • 238
                                Boat looks great you did an exellent job.One thing i notice is the prop looks very dull and im thinking it needs to be balanced and sharpened ? if so do it before you run it or it could cause serious problems and damage to your boat.
                                Mart
