HJ's First Twin Cat Build ''CF Daytona''
  • monojeff
    • Nov 2010
    • 2551
    Originally posted by HYDROJERRY View Post
    Sure thing on the scuffing but where do i start on the build,, i tryed to print out the pdf file template for the strut mounts but i checked it against the real mounts and its not the same size,, or sould i cut and install the water pickups first???
    Make sure you do not have any auto rotate and center checker or where it says fit to page sometimes don't realize you have something checked so have to play with it.
    Look forward to seeing this boat get built.
    Been busy so have not had a chance to work up the hatch decals for you but should have some time tomorrow.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • HYDROJERRY
      • Jan 2010
      • 2503
      OK guys ill do the struts first, as soon as i can get a template made!!! thanks Jeff as you can see i have a long way to go..
      • Rumdog
        • 6453
        Make a template using some clear lexan
        • HYDROJERRY
          • Jan 2010
          • 2503
          tryed again this morrning and Jeff was wright i had to uncheck the auto rotate and auto center and hit full size.. i think it worked wright or at least they look wright to me but ill have to wait and see when i get home...Thanks for the help there guys,,you too Rummy,,,
          • CHUD
            • 497
            lookin sweet
            she s lookin good bra
            • fatboyelectric
              • Feb 2011
              • 84
              • HYDROJERRY
                • Jan 2010
                • 2503
                Thanks bro,,
                i was playing XBox last night (blowing people away) so didnt get anything done,,,,
                • Boaterguy
                  • 1760
                  Just my excuse for homework:)
                  • CHUD
                    • 497
                    ha hj
                    Your not playing battelfield badcompany 2 onXBox sooo Hows the boatbuild
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      Hummm, any body got a big ass role of DUCKTAPE i could borrow,,Naw just playin,,i get home to late to do much and i have been talking to RayR,, he's been giving me advise so im hoping to do more this weekend
                      • CHUD
                        • 497
                        I thought that would fire you up bro going to drop the hydra in the lake in the morning wanta roll
                        • HYDROJERRY
                          • Jan 2010
                          • 2503
                          So i got some more done,,,,first i epoxied in the two cf plates for transum doublers to reinforce where the struts bolt on,,,then i took the templates that are on the fightercat site and cut them out and taped them to the outside rear wall of the transum,, i used clear Scotch tape to hold them cuz i can see threw it and it dosent hold so tight i cant get it back off easly,,,that way i can measure the space between the template and the tunnel edge,, i put the template 7mm to the edge of the tunnel and drilled my holes but only drilled the actual stuffing tube hole tinny just to line up the hole for later,,then ran my bolts threw to test fit,,as you can see i need some shorter bolts..And heres some pics..
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            Funny the things you find at the Autoparts store can you gess where i get the air rams,,,they where actualy chrome window washer squarters covers,, i just scuffed them and painted them black then about 6 coats of clear,,the have stick stuff under them but think im going to fill them with epoxy with a bolt in the middle so i can just drill a hole threw the hatch put them on and put a nut on the bottum but not sure yet but i think they look sweet!!! PS thats just dust on them from sitting outside drying,, they are glassy ass hell in person..
                            • CHUD
                              • 497
                              DizzAm That baby is sick ,I gess your going to let me have the first run hu bro
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                the first run,,yeah sure you can run around it all you want but dont touch this babies for grownups!!!!
