I have built up an Aeromarine SprintCat -- the small one - 29 inches long.
Running a Leopard 4074 motor @ 2000KV, on 6S.
That gives 44,000 RPM unloaded!
Using an Octura 442 prop - detounged, that should give speed somewhere over 70MPH.
I started out with a .187 flex drive, but ran into viabration and heating problems when I reved it up on the bench. Removed the .187 flex and installed a .078 wire drive. The viabration went away, but I still had a little heating of the stuffing tube.
Tried various lubercants, including luberplate, lithium grease, synthetic oil. I still had some heating, so I water cooled the stuffing tube.
I settled on a mixture of "luberplate" grease and Moble #1 oil. There is a resovour of lubercant in the adaptor (1/8 tube to the strut), so I only pull the drive to lube it, once every 3 runs.
I got about 8 runs with this setup and the motor, ESC, stuffing tube, and batteries are running cool.
The boat rides high and goes like heck! At 44,000 RPM, this thing "SCREAMS" when it runs.
I know that I am well above the normal RPM range, but everything is runing cool?
