MHZ Mystic build for Joseph Y
  • dasboata
    • Dec 2010
    • 3152
    I have the drives and rudder mounted,, the rudder is reinforced on the inside of the hull. I fitted and mounted the motor mounts and stuffing boxes, the motor mounts took quit a bit of time to fit them to the contours of the inside of the hull .I was not look foward to building this boat but once I got started I am very EXCITED Chris
  • HOTWATER
    • 2323
    Chris, did you do the CF work?
    "Will race for cookies!"
    IMPBA D12
    • dasboata
      • Dec 2010
      • 3152
      No,,,,,,,, that is a Kevlar/Carbon weave that is how the boat comes from MHZ nice ha ??
      • HOTWATER
        • 2323
        Yes sir...very cool looking!! Bullet proof even!!!
        -Kent
        IMPBA D12
        • fatboyelectric
          • Feb 2011
          • 84
          sweeeet!
          • johnf
            • Dec 2009
            • 1078
            Nice. Ready to see the finished product!
            Catching Air!
            • kookie_guy
              • 897
              What exactly do you guys use to attach things like the motor mounts to the hull? I'm assuming epoxy, but please be specific.
              • dasboata
                • Dec 2010
                • 3152
                this is what was recomended to me Loctite E-20HP hysol Epoxy and it comes from a reliable source
                • keithbradley
                  • 3663
                  This should be a nice build! Are you fitting a power system or just getting it ready for his motors/escs of choice? I'm curious what's going to push this hull, which is very nice by the way!
                  When I do the motor mounts in my boats I usually make them out of carboard first, that cuts down on a lot of the time spent fitting them. Being the experienced build you are, I'm guessing you already do this in some form, but I thought I would throw it out there just in case its something you have yet to try.
                  www.keithbradleyboats.com
                  • kookie_guy
                    • 897
                    thank you very much sir.
                    • dasboata
                      • Dec 2010
                      • 3152
                      Yes I did make templets out of cardboard but I ended up moving the motors so it needed some fine tweeking I am installing 4074 2000 KV with HK 180 ESC I was going to build the boat for myself but I changed my mind thanks for the nice comments guys !!! Chris
                      • dasboata
                        • Dec 2010
                        • 3152
                        I have gotten some more done
                        I mounted the C/F stuffing box supports installed 1/8" ID Twinn water pickups installed 8/32 SS blind nuts for the cowl have the esc trays done Check it out and LMK how you like it thanks chris
                        • dasboata
                          • Dec 2010
                          • 3152
                          and some more pics
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            Always looks so easy when i see everyone else doing it but,,eek
                            Everytime i look at mine im still building i just worry!!
                            • crrcboatz
                              • Jan 2009
                              • 914
                              Chris very nice work indeed. Hey I referred u to the person building the 56 Apache on here yesterday. He wanted opinions on cg for that boat. Did he contact u?
