BL Pro Boat Mini-Cat (Now the Mini-C)
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    Video @ post #102
    The following is how I convert a Pro Boat Mini-Cat to Brushless.
    I have lost my Pro Boat Mini-Cat to Davey Jones. The kind folks at Pro Boat (Horizon) replaced her with a Mini-V. I questioned the replacement, they stated that the cat, due to the rename, is not available. The Mini-V is the closest replacement. I took the V to my LHS, they exchanged it for me.
    Now on to the build progress...
    Parts list:
    3/16 brass tube.
    .098 flex cable w/ 1/8 stub/prop shaft (Octura)
    Motor of choice. (I'm using this ammo 28-35-2700)
    ESC of choice. (Team Orion Captain-35)
    Mini Hydro Hardware (From OSE)
    Prop of choice. (x427)
    2 part foam. (This stuff is awesome)
    I removed everything from the hull except the linkage boot. I inserted a coarse rattail file in the tube from the transom end. Rattail files are thicker in the middle. Once the file bottomed out on to the tube, I gave it a slight right twist, till I heard it pop.
    I used a small pair of vise grips on the front of the stuffing tube. I grabbed the tube and gave it the same slight twist till I heard it pop. Then I removed the Vise grips.
    I used the rattail file still locked down on the tube at the transom, and twisted the tube to the right as I pulled it out.
    Drill the hole at the transom with a 3/16 bit as far as it'll go. Then file out the hole at the other end. Mark the 3/16 tube length with the original tube removed. Cut the 3/16 tube to length. Insert the cut 3/16brass tube in the hole at the transom, guide it through the other end, and extending about 1-2mm at the motor side (like the original was).
    Make a 3 sided cut in the tub where the rear of the motor would be to make a flap. Fold this flap back. Get the 2 part foam. Hold the boat with the bow pointing down & hold the flap open. Mix 10cc of part A & 10cc of part B. Stir for about 10 seconds, then pour into the hole with the flap. This stuff does NOT push like the spray foam. it remains very soft like the fizz on your Coke or Pepsi. once it stops expanding, then it starts to set. Because of that, it won't separate, or bloat your boat. Once set, trim any foam that may have come out the flap, then close the flap and seal with epoxy mixed with paint for color.
    There is absolutely no flotation foam in this boat from the factory. and it DOES SINK! I know first hand. The pocket of air in the bow didn't do a stinking thing.
    Here's what it looks like after the foam is set.
    That's all I have right now...
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    Got the motor...
    Compare it to the stock motor:
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      Buying the mini hydro HW today from OSE.
      I can't cut the .098 flex to length till I get the HW installed.
      • Diegoboy
        Administrator
        • Mar 2007
        • 7247
        Mini Hydro HW ordered. Let's hope that Steven's fast shipping works the same for me too!
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          Got the HW today. (Thank you Steven)
          Here's a shot of the installation. That prop is only for the picture...
          • SJFE
            • 4735
            Wow what a clean install. Nicely done Sir!!!!!!!
            • Diegoboy
              Administrator
              • Mar 2007
              • 7247
              Wow, someone else posted in here besides me??
              Thank you SJFE!
              • Diegoboy
                Administrator
                • Mar 2007
                • 7247
                I went to the LHS today to get the flex coupler. .098 to 1/8. They are out. the last one sold was to me and it's at the bottom of the lake. It'll be in stock next week!
                I picked up the drive dog, and an X427 prop. It's not sharpened or balanced as yet.
                I also picked up the ESC it's going to run. I couldn't pass it up, because it was in my price range! (Cheap).
                Specs are on the link in the OP
                I installed the motor, and finally got to cut the flex cable to length.
                • frostyan
                  • Dec 2007
                  • 37
                  nice kitten very clean setup . were did you get the bailer
                  • Diegoboy
                    Administrator
                    • Mar 2007
                    • 7247
                    Thank you!.
                    That is the stock drain plug.
                    • SJFE
                      • 4735
                      Nice score on the esc!! So when are you building the sub to recover the first one????
                      • Diegoboy
                        Administrator
                        • Mar 2007
                        • 7247
                        When I can score the parts for the sub at a whopping $33.99!
                        That LHS has about 20 of those ESC's at that price. The bay sells them for over $50
                        The 45A version is $39.99
                        • Diegoboy
                          Administrator
                          • Mar 2007
                          • 7247
                          1st Video. Don't get excited, it's just the rudder throw for now.
                          Video <--
                          • eric-paul
                            Luke Propwalker
                            • 34
                            Diegoboy,
                            this build really looks cool. i am sorry you lost your first one. i am surprised there is no float foam in that hull. even worse that there is no bow access. that two part foam looks great, it's better than the spray stuff then? if i were to do the same thing, would you help me out?
                            • Diegoboy
                              Administrator
                              • Mar 2007
                              • 7247
                              Welcome Eric.
                              I'd be happy to help/guide you. The 2 part foam I got is awesome. it pushes outward as much as the foam on top of your glass of cola. When it's done expanding, it will then harden. It simply doesn't push like the spray foam will.
