I have a couple 64mm EDF's laying around, so figured I'd build an EDF boat. The EDF's are pretty decent, at 4s there's about 1000g of thrust each.
The hull is going to be out of rigid insulation foam. 20" long, 10" wide.
Motors - 2x 3500kv outrunners spinning a 64mm EDF fan each
ESC - 2x 45A hobbyking ESC's (non water cooled)
Battery - 2x Rhino 4900mAh 2S 20C (running in series for 4s)
Here's the initial concept design. Everything is 100% to scale. Still have to add the steering mechanism, which will be like an airboat, so this can glide on land.
