This all started with me finding a good deal on a complete SV27 minus the hull, and spiraled from there. I hadn't planned on building anything new this year, but I just couldn't help myself.
Running hardware is a mix of SV27 bits and other parts. Hull is an HOR DF knockoff. After playing around with the layout of parts, I decided to go with 1/8" ply rails in this one. I know they aren't necessary for strength, but it gave me a very convenient place to mount all the electronics and keep a nice tidy layout.
Holes are drilled for the trim tabs, but they aren't mounted in the pictures. Once I get everything solidly mounted on the inside it'll be stripped back down for paint.
Rough cut rails:
VERY rough placement of electronics:
With everything mocked in I get a good range of adjustment with the batteries to get the CG way fore/aft of the 30% mark.
Total cost (minus the $40 UPS charged for brokerage) is under $200 with everything so far.
Hoping to finish up the rails in the next day or so (need some 1/4" basswood to support the platforms for the electronics) and get the boat torn down to start on paint on the next dry day.
I've got a bunch of props from my 3.5cc mono to try out, but does anyone have suggestions on where to start with it? I have as small as an x438 up to an x447 with a couple three blades in there too (x437/3 and x440/3 IIRC). I've heard good things about the M445 on an SV27, so I would think it should be ok on the same motor/esc/batteries in a slightly smaller hull?
Rough cut rails:
