Skunkworks Mach5 30" Cat Build
  • FE_Chris
    • 906
    Hey guys. I am building this Skunkworks cat to race in the SSLSO class with our club this year. I have not gotten very far. I installed the hardware tonight so I really am just getting started. I got my order from Steven today so I almost have everything I need
    I do have a question. The two pics of the strut (1st pic and last pic) I took are differant, if you look I have the strut moved UP all the way in one pic, and moved all the way DOWN in the other. I wanted to know if you people thaught that I had enough ajustment in there. It's mounted up now so I hope so!
    Also, anyone know the CG in the boat?
    I need to get a tube bender....then I can get this build moving along....
    This is gonna be the setup
    SW's 30" Cat Hull
    Mach 5 Inline hardware .150 cable
    ProBoat BJ26 Brushless Motor
    Hydra 120 ESC
    4s1p PQ lipo
    Im hoping for 40 MPH and WOT turning. :-)
    Fast Electric and Fast Ford's / V8 Mustang Enthusiast
  • obrien
    • 1320
    Sorry this is a bit off topic, but what does LSO mean?
    • domwilson
      • 4411
      I have one. It has a Feigao 9XL, Hex 120 and aeromarine hardware and a x637 prop. Here are some pics. It's faster than my SV27 with a X642 on lipos.
      Government Moto:
      • FE_Chris
        • 906
        Limited Spec offshore. We call is SS or Super Sport cause instead of brushed 700's we are using SV27/PB brushless motors.
        Thanks for the pics....Damn your strut looks high! I guess the good thing is, if I set mine a little to low, I can always trim a little off to move it upward.
        How do you like the handling of the SW's Cat?
        • obrien
          • 1320
          what hulls are allowed in that class?
          • domwilson
            • 4411
            It turns real good like its on rails. Planes really nicely. I like it. The strut is up high because these have a tendency to porpoise. I'm going to install a 8XL, hydra 120 and a X640 in the next week. Probably won't get to run it or my other boats for the next few weeks, but it is definitely my favorite boat.
            Government Moto:
              What do you need a tubing bender for? Certainly not for the stuffing tube! You can bend K&S brass tubing very well with your hands, just go slow and have the piece longer than you need, cut it to length later. I just got finished bending a new stuffing tube for my 10S catamaran - its 5/16" diameter brass and if I can bend that by hand (it was easy!), then you can bend smaller tubing just fine. I can bend 1/8" tubing into a 3" diameter circle by hand with no crimping or collapse.
              DO NOT ANNEAL THE K&S TUBING! I do not know where this old wives' tale came from but it is BS. It bends just fine as it comes off the rack. If you do anneal it - it will be too soft and the cable or wire will not be well supported. And don't bother filling the tubing with sand or sugar or anything - it bends fine without collapsing. Just go slow and make gradual bends.
              • domwilson
                • 4411
                Fluid is right. You should be able to bend K&S by hand as long as the bends aren't too great. If you are worried about it collapsing, put the telflon and the flex in it before attempting to bend.
                Government Moto:
                • Diegoboy
                  • Mar 2007
                  • 7443
                  Fluid is always right, but inserting the liner and shaft will prevent collapse, but don't think it'll guarantee a usable tube. I tried that, it didn't collapse, but the kink was enough that pulling the cable out was tight! Needless to say, I couldn't use that tube and had to try again.
                  • SJFE
                    • 4867
                    I have a bender & Iv'e ruined 2 feet of tubing so far. When I get more this afternoon ima do it by hand.
                    • FE_Chris
                      • 906
                      Thanks guys you are right about the tube being easy to bend! Cause I think I am ready to glue and glass this bad boy in I want you to check the pics, I think it looks good but I wanna make sure.
                      I have the teflon tube running into the strut. The brass tube is right up next to it, I am going to move it away 1 mm and shrink wrap it up.
                      Also, as far as epoxying the stuffing tube in......I was thinking I would use some small pieces of fibre glass cloth AND epoxy. Thats a big hole to fill it looks like epoxy will just run right out!
                      Im gonna wait for some replys before I procede.
                      Also, I was gonna glue the tube....THEN glue the motor mount with motor and flex cable/collet installed that way EVERYTHING is lined up all nice and perfect. Well, actually, I would like to set the mount like this with some epoxy, then remove the motor so I have room to work and start glassing it on real good with the cloth and whatnot.
                      How's that sound?
                      • FE_Chris
                        • 906
                        Thanks dom. I guess i'll start with the strut all the way up when I go to test and lower it as I see fit. Looks like you have your batterys quite far back in the boat too.....COG needs them that far back?
                        Looks good man!
                        • domwilson
                          • 4411
                          I had them further forward and it ran too low in the water. With Lipos, it seemed to run better there. Chris at Fine Design recommended thats where I should start. He was right. As far as the stuffing tube. Maybe some electrical tape on the underside might work to prevent the epoxy from "bleeding" thru. Maybe someone has a better idea?
                          Government Moto:
                            I don't use the teflon, haven't for about ten years. But it is fine to do so, just remember you still have to use a good lube.
                            I always put pieces of tape on the underside of the hull to keep the epoxy from running out. A few pieces of cloth are a good idea too, or use something like MarineTex or JB Weld.
                            I usually mount the motor first, then move the stuffing tube around so that there is a perfect alignment between the drive cable and the motor....but I have done it both ways. Use whichever you feel most comfortable with, but just make sure the alignment is perfect. Sometimes I take an hour or more moving the motor or tube around, cutting the hole bigger if needed, until everything is just right. It makes a difference in the final performance of the boat and the life of the driveline.
                            Fluid is always right...
                            Not hardly - but I have made enough mistakes and seen enough mistakes over the years to know what usually does not work best. :blushing: If the K&S tubing kinks, then you are trying to bend it too sharply. Use both hands and your thumbs to make the bends. I have bent enough tubung over the years - many many dozens - to know that the method works well without anything inside the tube when you bend it.
                            • FE_Chris
                              • 906
                              Thanks fluid! I went ahead and grew a set, and epoxyed this bad boy in. I used a few pieces of cloth as shown on top, and I did so on the bottom too, just not as much. The epoxy is quite thick, and although it does run through the hole it's not a huge issue now with the cloth.
                              I have everything lined up pretty good. I am more comfortable doing things this way for sure.
                              Thanks guys. More to come....Im gonna have to finish the epoxy on the bottom later, than after that dries I am gonna do the mount. seeya!
