34" ul1 ply wood build
  • Jesse J
    scale FE enthusiast
    • 7818
    SWEET!! Whatcha gonna do for flotation?
    "Look good doin' it"
    See the fleet
    • scoota
      FE DOWN UNDER
      • Dec 2008
      • 439
      I have a big block of styrfoam that im going cut to shape to fit in the sponsons before i lay the decking & i will have some stuffed inside the front of the tub as well ...
      hope to finish this with in a weeks time , all my hardwear & motors have turn up for my next build , a 44" Avenger Pro cat , im dropping in 2 leopard 5682 1670kv motors on 6s each , will post that build in a few weeks .
      jason
      UL1- 1515 castle/neu / 240 swordfish
      SV27- with UL1 running gear
      33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
      • Jesse J
        scale FE enthusiast
        • 7818
        That oughta work perfect! One other question/suggestion: are you planning on reinforcing?
        I would be reinforce the entire tub with FG or CF - you want that as rigid as humanly possible; any flex will cause you drag.
        One other idea: you might want to place her on a building board before reinforcing and applying decking; this will ensure a true and square hull, since you don't have any bulkheads to help.
        See the fleet
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 439
          you beat me to it jesse , i have been tossing up on , what to do about reinforcing the tub , i was looking at FG ,to keep the tub nice & open , but weight ? so may add some bulkheads once i work out the lay out of the motor , stuffing tube , ect ???????
          • scoota
            FE DOWN UNDER
            • Dec 2008
            • 439
            Keep any tips coming im new to this hull building , im a diesel mechanic by trade so nut & bolts is more my go ... like the old saying you never stop learning !
            Cheers jason
            • scoota
              FE DOWN UNDER
              • Dec 2008
              • 439
              Didnt get a lot done today fitted a sports 20 flat bottom strut & the stuffing tube , im using a SV27 motor mount , im making up some feet for the mount ..
              • scoota
                FE DOWN UNDER
                • Dec 2008
                • 439
                I cut & shaped the styrfoam to fit into the sponsons , made the motor mount , im going to lay some FG cloth where im going to fix the mount to the hull . been flat out at work so i havent got much done this week ..
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  lookin very good - next thing you know people gonna want one of your designs!!
                  See the fleet
                  • scoota
                    FE DOWN UNDER
                    • Dec 2008
                    • 439
                    Got all the hardwear in place today & mounted the motor & made a servo mount , the build at this stage weighs 4- 1/2 lbs with the motor , servo & hardwear... just got to make the two side skirts that run down behind the sponsons then i can lay the decking ..
                    • scoota
                      FE DOWN UNDER
                      • Dec 2008
                      • 439
                      just working out the lay out of every thing & running the cooling , i made up some water manifolds to keep it all neat .
                      • scoota
                        FE DOWN UNDER
                        • Dec 2008
                        • 439
                        Got all the bottom of the hull finished , just have to lay the decking & seal it & im ready to rock & roll , im quite happy how it turned out , the hull is nice & true , well its straighter than my AQ UL1 . it weighs just under 5 lbs without the lipos
                        • RCKong
                          • Sep 2009
                          • 1680
                          Is the peice of ruler that you built into the boat to help find the center ? LOL
                          great job on this scratch build hydro, cant wait to see it in action !!!
                          • scoota
                            FE DOWN UNDER
                            • Dec 2008
                            • 439
                            Started the decking today , should have it in the water in a few days
                            • Boaterguy
                              • 1779
                              • bardahlracing
                                • Feb 2011
                                • 43
                                By the way the stock ones run that should be a great boat to drive/race, the UL-1s seem so stable right out of the box, I was impressed with my 1/12 scale elam but it seem s the faster I go the more sponson walking I get, I have added a UL`1 strut etc. for adjustability, we`ll see,
