Well since I just received the stuff for the build after this one, I suppose I should try and get going on it.
This one is a little different, as the hull will be completely dry. The motors and escs will both be air cooled. It should keep the hull nice and clean and simplify things.
Power and hardware plans are:
* Twin suppo 3126 outrunners (2200kv)
* Twin castle ICE 100 escs
* 4s1p per motor (5000mah 46/92C)
* Twin .150" flex (.187" shafts)
* Twin 4mm stingers drilled out to accept .187" shafts
* Twin x442 L/R props
The hull will be strengthened with carbon fiber. Motor mounts, servo mount will all be made from carbon fiber as well.
I also have a pair of 3126 outrunners in a 1300kv wind, so I could swap them out for more speed if I wanted and run the same batteries in a 8s configuration. The ICE escs are good to 8s!
