Finally got a hull. Its an oldie
  • frostyan
    • Dec 2007
    • 42
    I think I got a good deal. If not o well I like the hull . Got a AEROMARINE SPRINT CAT . She’s in ruff shape but it has all the hardware and radio tray . with time and money going to have her like new .I have no idea what to juice her with . The hull is Length 36" 915mm x Wide 14" 356mm all fiber glass. So what do you guys recommend . Paid $120 for it and a free cat stand lol.
  • Diegoboy
    • Mar 2007
    • 7444
    ...are you good with FG?
    • frostyan
      • Dec 2007
      • 42
      going to make it FE . why ?
      • Rex R
        • 1007
        it is going to take a bit of work to patch/plug those holes in the hatch and make it look good.
        • SJFE
          • 4867
          Put her on a scale bud. We need and idea of weight to help with power systems. If I had to guess a KB10XL on 6s with a hydra 240. You may however need one of the larger Neu motors to get the torque you will need. This one going to cost you quite a bit.
          • frostyan
            • Dec 2007
            • 42
            it weights 6LB as is. good point , by the weight i mite have to go HV ESC and 24 cell .does the 45 Kb Brushless Motor have info torque .a buddy of mine works with fiberglass i have to take off all the stickers an give him the hull to fix it . the best way to take of sticker is with a hair dry or do you guys have a diffrent way.
            • SJFE
              • 4867
              Go to aeromarine and see how much a new uncut hatch is befor you go nuts glassing. I think you will be fighting a loosing battle attempting to use Nimh batteries. It will amount to just to much weight. I can really identifie with your excitement with regards to building a big cat. The fact is the components needed to power this cat reliabley are going to be very expensive. My honest opinion is to avoid this hull as your first build. I would shelv it for later on when you have gained the knoledge needed to do it right. What you need to build is one of the 26 to 30 inch monos or cats. A build like that will be half the cost and will be much more fun with far better results. The chance of failures that will cost money and stress will be much less. Sorry if that's what you where not looking to hear but I am looking to save you money and grief.
              Tom G
              • ReddyWatts
                • 1756
                If you are determined to use this hull, this is a setup I would use.
                KB45 11XL 1000KV
                High Voltage controller, highest amp rating you can afford.
                Lipo 8S2P 30C or 24 NiMH cells, but will add weight.
                M545 prop
                NiMH 70 - 80 amps 24300 rpm
                Lipo 80 - 90 amps 26800 rpm
                40's
                ReddyWatts fleet photo
                • Diegoboy
                  • Mar 2007
                  • 7444
                  Sorry... Good with FiberGlass is what I was trying to say
                  • SJFE
                    • 4867
                    Ok having seen it on my PC and not my phone I can make a few suggestions. The first thing I'd do is cut the fat. I am unfamiliar with that hull but I'm betting you can out most of the stringers and remove the radio box with out compromising and strength. The cracked hull section needs a fair about of glasswork. I am not the person to talk to about that. OSE does stock what you need though. I you can cut & sand 2 or 3 pounds out of her you will have a fighting chance. Mr Watts setup up suggestion is "Spot On". You are looking @ about 400$ in parts and 250 to 300 in lipos. Half that for Nimh batteries. Try and save that pain...It's a nice looking cat ]Ok having seen it on my PC and not my phone I can make a few recomendations. The first thing I'd do is cut the fat. I am unfamilure with that hull but I'm betting you can out out most of the stringers and remove the radio box with out compromising and strength. The cracked hull section needs a fair about of glass work. I am not the person to talk to about that. OSE does stock what you need though. I you can cut & sand 2 or 3 pounds out of her you will have a fighting chance. Mr Watts setup up suggestion is "Spot On". You are looking @ about 400$ in parts and 250 to 300 in lipos. Half that for Nimh batteries. Try and save that pain...It's a nice looking cat
                    • Avanti
                      • 1298
                      to remove the sticker a hair dryer will help. Have goo gone on hand you will need it. start at one end and move slowly across the hull try to get it off in as big a piece as possible to make it easier on yourself. also if it is glass and gel coat you can use acetone on it to clean it up to give to you glass guy.
                      The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                      • frostyan
                        • Dec 2007
                        • 42
                        allsome going to work on the hull now with the hair dry .thanks for the set up reddy , and which esc can i put thats water proof because i removed the radio box.
                        sjfe these are the stringers 22.JPG and radio box gone
                        • ReddyWatts
                          • 1756
                          Offshore will be selling the Castle Creations Marine Hydra HV 120 and HV240 controllers after the first of the year. Dont know of any HV controllers that are waterproof.
                          Brushless DC motors, ESCs, and voltage regulators (BECs) for RC, robotics, UAVs, and more. Engineering in the USA for high-power, precision control, and reliability.
                          • ReddyWatts
                            • 1756
                            I am using the OEMRC HV 100 amp controller on mine with NiMH cells. I am uncertain about recommending it for your setup, because of the heavy hull weight and power surges. It is about $100.00.
                            The Hydra controllers are the safe and best option.
                            • SJFE
                              • 4867
                              I'm sorry but did i see a list price of 540 on all of them?????? Holy Shnikeies!!!!!!!!!!!!
