this is my 1st mini rigger . whats your thoughts?
my 1st mini rigger
It look to be built nicely, did you laser cut it yourself ?
Is is a kit or a known design or your design ?
I am curious about the openings on the sponson tops, will they be closed ?
How long is the tub ?
What will make it go ?
I know I am full of questions, just keen to see what other folk do with small wooden boats.
Simon O, i wish i could say this was all my work but no its from http://www.r2hobbies.com/eng/proddet...od=rcbt0401005 . My idea has allways been try pre bought see how it works then build from what i have learnt, so this bad boy will be powered by a 1880kv 540/3660 Inrunner Brushless Motor and a 120A ESC Speed Controller i have a few lipo batterys that will fit but will start of small and work my way up to see how far i can push this thing.
At 19.5" not really what I would call Mini but that is what it is called, so I'll roll with that.
A 540/3660 is considered a large can and for me quite large for this size of hull.
My choice of motors would be a 3650 which is a S size motor.
At 1880kv you will need a lot of volts to get a suitable shaft speed, 4 cells minimum
Fwiw I have a few riggers and my mid size one that is a lot bigger than what you have there would suit a motor the size you have. The rigger it was developed from ran S(3650mm) motors with a lot of fun.
I am keen to offer advise based on water time. No records held here but some extensive "testing" (burning) of components has been done to get where I am.
Keen to help
From my findings I can say that it does not make a lot of difference, especially on a straight run, The very clever rigger racers will be able to tell you what is optimal especially for oval racing.
For me I run them wide and turn slow as that is how I have to at the thin end of my favourite pond. I am a solo semi-saw boater so some of my ideas are not applicable for everyone.
what about a e-flite 2000Kv brushless? The 1880kv 540/3660 Inrunner Brushless Motor and a 120A ESC Speed Controller was what the manufacter suggested i run . I have a 1800mah 2cell 7.4v which fits nice and a 7.2 2200mah that will fit snug aswell
On 2S or7.4 a 2000kv or 1880 motor is way too low kvOriginally posted by zanda View Postwhat about a e-flite 2000Kv brushless? The 1880kv 540/3660 Inrunner Brushless Motor and a 120A ESC Speed Controller was what the manufacter suggested i run . I have a 1800mah 2cell 7.4v which fits nice and a 7.2 2200mah that will fit snug aswell
For 2S you need twice as much Kv ortwice as much voltage for those motors.
My last rigger that was about that size ran a 4400kv on 2S, 5000kv on 2S and a 2950kv on 3S.
Your esc should be fine for all of those setups.
You need to get your revs up
Simon.O nice work on you twin cat. i have been building one for ages but lost interst hopfully this rigger will get me back into the hobby
Thanks for the compliment, I just kill trees to make dodgy looking hulls. There are some real clever buggers here and I am only half clever. If you want the best of info then PM some of the real fast guys, that's what I do when I am stuck.Originally posted by zanda View PostSimon.O nice work on you twin cat. i have been building one for ages but lost interst hopfully this rigger will get me back into the hobby
I am keen to help you here with this new hull and with any luck (for you) there will be others who are keen to help too.
