Twin cat 32"
  • nikos222
    • Jan 2010
    • 25
    Twin cat 32"
    This is my new cat.
    The hull is a hotr 32", and I'm going to make it twin.
    First of all i make a carring base. I can use it as an workbench too.
    By nikos222 at 2011-01-25
    By nikos222 at 2011-03-06
  • tunnelvision
    • 685
    Nice, I just picked one up too. Going with the GEICO theme. What is going to be your setup?
    Go Fast...Turn Right...
    • nikos222
      • Jan 2010
      • 25
      Then i lay a carbon twill 225gr/m2, inside the hull.
      It takes me about three days, trying to do my best.
      And...
      By nikos222 at 2011-03-28
      • tunnelvision
        • 685
        Looks good to me! I think I am going to put fiberglass, may use carbon fiber. Haven't decided yet. Good luck with the build and keep the updates on the progress coming.
        • nikos222
          • Jan 2010
          • 25
          Thank you tunnelvision.
          Next step : COG control, and installation of motor mounts.
          I have already 2 x Leopard 3674, 1900 rpm/V, and i'm waiting for the ESC's, 2x180A.
          I think that on 5s, maybe it will be better a couple of x442. (L/R)
          Stinger shaft: 4mm, flex cable : 3.2 mm.
          • nikos222
            • Jan 2010
            • 25
            ...common base for receiver, battery pack, servo and
            temporary esc's arrangement.
            By nikos222 at 2011-04-26
            ...and the final view at the end of works.
            By nikos222 at 2011-05-19
            By nikos222 at 2011-05-30
            • maker
              • May 2011
              • 14
              Now this looks like a real nice build :P how much do somthing like this cost?
              Hope to see some pain job or atleast a youtube vid of the boat =)
              Keep up the good work!
              • keithbradley
                • 3663
                Looks great nikos! I think the combo you have chosen (1900kv @ 5s w/x442's) is perfect. I have a similar boat.
                This should be a fast and fun boat.
                www.keithbradleyboats.com
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  About 24cm from the sponson transom for COG should work well. That's where I've got mine set.
                  Good to see HOR has the new hull stock. These are the updated hulls which seem to handle better at higher speeds than their predecessors.
                  I run a pair of K45's for sport. Cheap repair in case of turtle incident.
                  • nikos222
                    • Jan 2010
                    • 25
                    ...early at the morning, Nea Makri, Athens, Greece !!!
                    By nikos222 at 2011-05-31
                    It was the first run for my new twin cat, and i am very happy.
                    I try : 2 x 4s, 2 x 442 (L/R).
                    Everything, cool. Everything, dry.
                    My next run maybe will be with a pair of 1,4 x 43,5mm (R/R) !!!, or 445 (R/L).
                    Enjoy the sunrise in Greece through the next video.
                    Thank to all of you.
                    • millzee
                      Ozzie Bloke
                      • Nov 2010
                      • 1092
                      nice work mate, well done
                      "Gimmy Toyz for FUN"
                      • nikos222
                        • Jan 2010
                        • 25
                        Hi, Maker.
                        The total cost is about 600-700 USD, (!!!).
                        (Hull, batteries, motors, ESC's, hardware, carbon fiber, etc...)
                        ...but it was realy nice and interest the whole construction.
                        • keithbradley
                          • 3663
                          Looks good and a beautiful pic as well. Why not leave the x442's on and run on 5s? Wasn't that your original plan? Those x442's will hook a lot harder on 5s
                          • nikos222
                            • Jan 2010
                            • 25
                            Yes. That's true keithbradley.
                            The first plan was 2 x 442, on 5s. I haven't change that.
                            But i like to try a pair of R/R props to see the way that it runs,
                            and i think that it's better to do that on 4s.
                            • kookie_guy
                              • 897
                              Are you gonna change out the complete flex cable and everything? If your current setup is L/R props, then I'm assuming you are using an L/R flex cable as well.
